Alignment dowels for dining table
AZ in Colorado Springs
I'm building a dining table for my daughter. It's not really big, 30" wide and 60" long. She has a small town home in Virginia (so it's being built in an arid climate and will be delivered next month to a swampy climate).
The top is in two pieces (and the halves are made of laminated maple strips). I'll also make two leaves for the table. The immediate problem is lining up the holes for the dowels that align the two halves and provide some stability for the leaves, when they're used.
I can't come up with a way to secure the table top halves, and the leaves, in the drill press without a significant undertaking. So, I'm thinking of making a block that will sit on the edge of the stock, and register to the top side of each piece (as I sand them, the thicknesses may vary a little bit). This block will be thick enough to guide the drill for a straight hole.
Are there any better methods to use, in the absence of a horizontal boring machine?
I don't have a festool domino, and I think biscuits would just be wrong.
Thanks
Re: Alignment dowels for dining table
Keith Newton
Rather than making a drill guide for a single hole, I make one the same length as the table edge, and drill all pin locations on the press.
Then clamp face A to one side and B true opposite, making sure to also index off the same end. The space between holes is even less forgiving than up and down. This will also save you time.
Sgian Dubh
A slight modification to Keith's suggestion will make it easier still to fix his jig or guide in place to ensure accuracy. After boring out the holes in the piece of wood as suggested, fix a piece of wood, plywood or MDF along the top edge to form a T section - this piece of wood needs to be cut and fixed accurately so the two outer edges of the T are parallel to the faces bored to guide the drill bit. The underside of the arms of the T then sit flat on the top side of the leaf or panel and some clamps hold the guide securely in place. The last thing needed is a mark squared across the top face and outer edges of the T to line up the guide with corresponding marks on the panels or leaves.
I suppose it's not really necessary for me to say the top of the T shouldn't be so wide that it prevents the chosen drill bit boring deep enough into the edges of the leaves, but I've said it anyway. And if there are several holes to drill I'd choose, for durability, a close grained hardwood such as hard maple to make the leg of the T. Slainte.
It Worked for Krenov
Jesse Cloud
The method described by the earlier posters should work well.
Krenov was a fan of dowels and used the jig described to register holes for drilling.
Not to compare myself with Krenov, but I made a nice hanging wall cabinet with that technique and its still quite solid ten years later.
Somewhere I have a dowel jig...
John in NM
If my wife can find it in my tool box, or if you can wait til I get home Friday, you're welcome to borrow it.
It was a steel block with holes and clamping aluminum sides. Real easy to use as I recall. I think I kept it, and know where it is, but since it's been 15 years or more since I used it my memory may be faulty.
Rockler or someone like that is sure to have the tapered end dowels that industry uses for table leaves, but you can always make them yourself chucking them in the DP and filing/sanding one end to a point. I don't bother with dowels for glued joints, but they are good for table leaves.
Ralph Lipeles
I've done it your way but with a slight mod. I made the drill guide piece exactly the same thickness as the table top and about 1 1/2" wide. Instead of MDF I use wooden strips 1/4" by 1" by 5" one on the top side of the drill fixture and one on the bottom side. I use 3 or 4 sets of these strips. When drilling, the fixture slips nicely into place and I can use clamps on the strips for extra insurance.
Biscuits work very well
Dick Coers
I don't glue them in. We keep a little bag of them stored with the leaves. It's worked for 20 years for use.
Thanks for these great suggestions. I hadn't considered making the jig to accommodate side-to-side spacing as well as registering to the top face.
John, I've used a dowel centering jig before, but I was concerned that in sanding the top nice and smooth, the boards might end up not the same thickness. (Maybe the variance will be so small it's not worth worrying over.) So, I want to make a jig that registers off the top face of the top.
I don't own a dowel centering jig. Perhaps I can take you up on your offer the next time I drive down to visit my son in Alamogordo.
I love woodcentral!
Any time...
John in NM
We're right on the way to Alamo if you come down 54, stop in for a visit even if you don't need the jig. I'm going to be home on weekends from here on out, then down at Sunspot during the week. Easiest way to reach me is at jdowney@plateautel.net
I see what you mean now about registering from the top - those jigs center the hole, but if there is much sanding on one leaf vs the other, that may not work out as well for you. Of course, you could put the locating dowels in and sand the leaves and ends all as one big top too.
Kneale Brownson
Re: Somewhere I have a dowel jig...
Kneale Brownson
Probably just like the one I've used, along with a set of markers to mark the other side of the joint so I can get them aligned.
Hay, I got one of those....and....
....the last time I used it was to install table leaf pins.
Kneale Brownson
You could glue them in one side.
