Taking apart PVC dust collector pipe
Jesse Cloud
I'm helping a friend who's moving his shop.
He has PVC pipe for his dust collection. The pipe is very hard to take apart at the joints.
Any tips on how to do this?
Re: Taking apart PVC dust collector pipe
Did he glue them together? If so, you have to cut the pipe (Sawsall or whatever).
The glue dissolves the PVC somewhat and as the solvent evaporates, the two portions essentially become one.
Now if he didn't glue them, that's a different story. I find that using a band or strap wrench helps. You put one on one portion of the pipe and another on the adjoining portion and twist and tug.
John McGaw
I've found that tapping the coupling with a deadblow mallet while pulling and twisting helps a bit. Not so practical for one person but with two it should be easy. As you suggest twisting with a strap wrench would be a great help. I was trying to work with 6" PVC up near the ceiling and that isn't a great way to get any torque on the pipe.
in additon
Bashing the lip with the aid of a block of wood and hammer helps too.
If the sections were glued, must be sawed apart. Often if the internal piece is scored nearly through its thickness with a section of hack saw blade it can be broken cleanly off the female joint with a chisel or screw driver employed as a chisel. I repair irrigation line this way with great success and even greater aggravation for having broken something like a riser.
Oil filter wrench?
John in NM
Sorry I'm not there to help you guys!
If the strap doesn't grip, or you don't have one, a good oil filter wrench might do the trick, basically a bit of bicycle chain with a lever handle that makes it tighter the more you pull on it. Might be too small for the pipe of course, never tried it on 6" pipe. They make pipe wrenches in a similar configuration, but those won't be as cheap and readily available as a filter wrench.
Its the dust that makes them so hard to pull apart - when we were building our house I dreaded dry fitting PVC joints in the drain lines, because any dust in them made it hard to pull apart. Luckily for the drain, an 1/8" here or there on the fit didn't seem to matter much.
Re: Oil filter wrench?
You can cut little strips of pvc and glue them on the pipe to make cleats to grip.
Modified strap wrench *LINK*
Tom Dunlap
I had a strap wrench with a strap that was too short.
It was really easy to replace the short strap with some 5/8" wide webbing from a climbing sling.
Tom
Strap wrench
