Same project different area as earlier
Gary Smyth
Recap: Installing additional furring to enable cabinets in laundry.
Project dominoed to enable additional cabinetry in laundry. When first addressed the wall had two layers of 1 x 2" furring horizontal at baseboard and ceiling level. Inexpensive paneling basically just hanging with nothing behind. The wall behind is concrete block (some below grade) with outside exposure. Water pipes anchored to the wall in many directions to laundry, bathroom and routed to kitchen. Which I suppose is why the paneling just hung there. Never had a problem with freezing pipes as (perhaps) room air was unimpeded inside the 1 1/2" cosmetic hanging panel curtain.
Question. Now that the water pipes for this section are enclosed (blue tape) is there something I should do before I close up the space? IF I insulate with foam or other stuff one portion of the water pipe will still be attached to the wall. Will enclosing them make matters worse? I would rather not undo all of the water pipe anchors to isolate the pipes as that is a whole other can of worms. I do not want to make additional work. What think you? Can I close up, as is, add insulation, (what type) or (worst case) tear it out and isolate or reroute pipes? Right about now I want it done but want no problems next February.
