Computer guy Question, OT Pictures
I do VA and FHA inspections, general on Specially Adapted Houses for Veterans.
Pictures are required and I use my I-phone to take them.
I am not a computer guy and am just barely hanging on to the technology. My observation is that as soon as they make computers bigger and faster, they make programs larger and more complex and resolution on pictures enormously bigger. Sort of a spinning the wheels contest with out much apparent gain for me.
The other part of the problem is that VA has a system even more ancient than mine and has a fairly small file size limitation. Combine that with gummit employees that know even less that I do and care even less and you get chaos.
I have been using Adobe Acrobat to compress pictures to get them under the file size limit. I bought the program and computer out of my pocket to be able to do this. Also bought the I-phone. Don't have a IT Department paid for with tax dollars to support me, thus I turn to you.
Typically, I import the pictures into Word, label them, and them convert that to a PDF. Apparently that compresses them enough so that I can send 6 or 8 pictures in one document. Now, the conversion has stopped working. It starts and immediately locks up and them I have to shut down Word and do some sort of recovery. I don't know if the problem is in Word or Acrobat. Both are older versions and no longer supported. I really don't want to buy newer versions. Don't want to spend the money. Don't want the learning curve. I assume they would be even less compatible with the VA's system.
There's not much income in this. I would quit, but I kind of like helping the Vets.
Anybody got a good way to compress I-phone pics to send them to ancient tech or to fix my crap.
Re: Computer guy Question, OT Pictures
ben d.
I use Picasa for all my pictures and it is a free program and will resize the pictures for e-mailing and I really do not know how many pictures that you can e-mail at time, I have mailed as many 25 at a time without any problem. You can do a lot of other things with the program such as crop, lighten, re-touch and add text to the picture.
Google Picasa and download for free.
You can plug your phone in and download directly to Picasa.
Should you want to post a picture somewhere outside of Picasa other than e-mail you will have to export it to another place such as documents. It will also copy all your pictures that you have into Picasa automatically if you set it up that way.
Not a hard program to use and it is free.
ben d.
Not an expert...
John in NM
But a couple things do occur to me here. First is that you could perhaps use a camera instead and set it to the lowest resolution. Perhaps that shows you how old my camera is, but it's lowest resolution is a pretty manageable size file :D That may not be the case now as CCD's get bigger and bigger.
For resizing pictures, I use a linux program called gimp. There is a "scale image" feature under one of the pulldown tabs where you can simply scale the whole thing down to a reasonable number of pixels. Windows and probably mac versions are available for download - and I remember some kind of problem with that discussed here about 6 months ago. As I remember, someone picked up malware through an un-official download site. The stuff is free, so just go right to gimp.org or whatever to get it if you want to try it out.
The reason I suggest this program, or any other resizing program for that matter, is that it seems that getting your pictures down to a manageable size before doing any other work with them would save you some aggravation.
Re: Computer guy Question, OT Pictures *LINK*
John McGaw
There are a multitude of ways to skin that particular cat. Easiest would probably be to download a program which does the job and there are quite a few of them out there. One which comes up in a search is "Free Picture Resizer" available at CNET. I don't use it myself, having a couple of other solutions on my main system, but this program is pretty well rated for simple tasks. Slightly more complex and capable is Irfanview, also free. This program is a slam dunk for image work and many people use nothing else. http://www.irfanview.com
http://download.cnet.com/Free-Picture-Resizer/3000-12511_4-10297789.html
Joe in a Cleveland suburb
Another super easy solution is:
http://www.faststone.org/
Try the resizer app.
garthinsandiego
I too often use Word to manage picture size. After importing the pictures to Word click on one of them and you should see a "Format Pictures" menu pop up above the menu bar. From there you can select "Compress Picture" and then select the appropriate reduced resolution. You can chose whether to apply the compression to the image selected or all in the document. Obviously you can crop the pictures before compressing to reduce file size even further.
This feature has been included in Word for a long time, but how you access it has changed. In older versions I think it was found under the "Format" tab.
Hope this helps. - Garth
The problem is....I don't understand.....
Whats going on. And I don't really want to. Don't want to be a picture manipulator. Don't care how a computer or the Internet works. Don't want to rebuild the GPS system, just want to use it.
I don't understand why the VA system won't accept the pictures other than I get a Terminal Fail notice say the size was too large.
Sigh... I guess I am going to have to understand some of this stuff. Fully confident it will all change by next month.
An example is the cell phone service I deal with sold their band width to somebody else and is leaving the area. They are terminating my service. They sent a letter saying that if I would wait until after June, they would not charge an early termination fee. WHAT? What happened to the contract? Clearly a one way deal. They should pay me a fee.
OLD Fuddy Duddy signing off.
Thanks Garth
I tried that but could not see an easy way to see how much compression took place. I compressed the entire document but as near as I could tell, it had no effect. I feel like I missed a step. Some sort of "do it now button".
Perhaps I will play with it when I am in a better mood. Perhaps the computer will survive without a gunshot wound.
Frustrating, isn't it? *LINK*
John in NM
You just described my perennial irritation with our computer systems at work, and more specifically my future former boss who "maintains" them. I can only hope the new bunch is more up to date and efficient.
I don't know how old this link is, but it might give you a few options. Still seems easiest to me to shrink the pics before getting too involved, then the problem should just go away.
http://smallbusiness.chron.com/changing-megapixels-iphone-47183.html
garthinsandiego
To verify compression is taking place, save one of the compressed pictures from Word to file as a picture and then compare file size between that and the original. I'm using Word 10 and no longer able to access earlier versions. I know the process has changed somewhat but can't recall the details.
William Duffield
If you are using MacOS, you should have no problems, and it should cost nothing. You can crop, rotate, and compress your pictures using Preview. It is a simple application that comes with the OS. If you don't have Microsoft Word, you can read, edit and write documents in Word format (.doc) using OpenOffice.org. It is also free. The other alternative is the Apple application, Pages, which is free with the latest versions of MacOS. You don't even need to download and install Preview and Pages. To convert your document to PDF, Apple has built the Acrobat formatting engine into the OS. In just about any application that creates documents that can be printed, in the Print dialog box, there is a PDF button, that will create a .pdf document for you, instead of sending the document to the printer. So, you don't need to buy Adobe Acrobat either.
I needed a high resolution 27" (5K, 5120x2880 pixels, retina display) monitor. The best one, and cheapest, that I could find was about $2500. It includes an iMac (built in), and and wireless mouse and wireless keyboard, and MacOS 10.10, that are basically free with the monitor.
sent the pics in Google Drive
The ever helpful Google popped up and said "File too large? no problem, use Drive"
So I tried it. Opened it (if that's the right term) and about half a dozen pictures popped up, one of which was nude some joker sent me about two years ago that I thought was deleted. Stumble through the process and sent the pictures. The Answer from the minions at VA was "can't open Pictures".
Not, We will figure it out, or we will get the IT guys on it, nothing, not even thanks for trying. Then they said they can't pay the contractor until I send the Pics. No pic's nobody gets paid. Not even me. I thought I got paid to be an Inspector, not a photographer.
resizing pics
Walt
Like John, I use GIMP. GIMP is sorta like photoshop lite so overkill but hey, the price is right :-). To shrink a photo, I open it in GIMP then select on the menut at the top "image -> scale image". For online posting, I often use 1024 X 768. Set the top number, either larger or smaller then tab to the other. The correct pixels will be there to maintain aspect ratio. There are other settings, I leave them at default.
Next I select "files -> export image" There are a bunch of file type choices but I only typically use 3, either .jpg, .png or sometimes .gif. Once I select file type and click 'export' another window opens to set quality. For .jpg intended for screen viewing I use about 25. This procedure will take a 748k jpg down to 88k without noticeable degradation for onscreen viewing. Takes longer to read this than to resize a pic. GIMP will do a lot more but the only other functions I use frequently are brightness-contrast and cropping.
don stephan
Try compressing individual photos rather than a Word document.
If you save the compressed photo using a different file name your file Utility shows file sizes.
Dale Stansbery
I've always used Irfanview to manipulate Pics, and I've never found anything simpler to use and free at that. The first step is to crop, then resize the cropped photo. To create a Pdf, I use a program called PublishIt Pro which is about $36 I believe. That program is kept up to date for new releases of Windows with no charge for updates. It's simple to use, and the photos can be added by drag and drop, and text can be easily added since it's a publishing program, then save as a Pdf file. I find it a much easier process to format than a word processor.
Very long but perhaps not long enough
Barry, I did this type of work for years before I retired. I have seen so much confusion in this field, even from IT departments and the supposed graphic arts professionals at magazine publishers. (Don't get me started on DPI)
I realize you don't want to get a PHD in this, but there is some basic understanding needed. Here is the kindergarten version. My apologies if you already know all this.
There are two things going on here to make your life difficult, possibly three. The image resolution, the image compression, and possibly the image format. In image upload hell there may be a a fourth on a particularly stupid system: image aspect ratio. Or a fifth or sixth: orientation or DPI. Dumb, dumb, dumb.
Assuming the VA system will not choke on the image format and flavor you send (jpg, png, gif, etc), it probably has specific file size limitations just like many internet forums including this one. The biggest question: does the VA have any published image upload specifications?
Most system have only FILE size resolution only (e.g. 100 kilobytes max). Some less intellegent systems have placed arbitrary IMAGE size (resolution) limits on their image uploads (e.g. 1024x768 pixels max).
Finding the exact requirements may be difficult, especially if the guy who wrote the software died and no one else has a clue.
Unless you can find out their exact requirements for the VA system lets assume the only limitation is file size. Some systems have rediculously low file size limits, mostly for historical but sometimes financial reasons.
The FILE size of an image depends on two interrelated things, the IMAGE size and the COMPRESSION. If the compression levels are equal, a smaller image (say 640x480 vs 1024x768) will have a smaller file size. To complicate things, the compression is often called image QUALITY, where a higher quality has a lower compression. There are many other details here I hope you don't need to know.
If the image sizes are equal, a higher compression will result in a smaller file size.
While you can reduce the image resolution by trial-and-error to reduce the file size, it is FAR easier and quicker to simply compress the file more. If the VA upload server is particularly stupid, you may have to do both. Unfortunately, increasing the compression is also a trial-and-error process. Fortunately there is a non trial-and-error solution.
Hands down, the best software I have ever used for image manipulation is Photoshop. While it would be insane to run out and buy the full Photoshop for your needs, Adobe does (or at least used to) sell an inexpensive stripped down version called Elements. A quick look at their web site indicates Elements has the function you need. This makes things SO easy.
The function is "Save for web". Yes, you can reduce the image size and increase the compression, but "Save for web" lets you specify the exact file size you want. Enter one number, click a button, done. I have used this hundreds of times and it always works.
Now if the VA does specify a file size maximum and still won't take your file, something evil is going on. Maybe their system is broken. Perhaps they choke on image aspect ratio (e.g. 16:9 widescreen vs 4:3) or something dumber like accepting landscape orientation only. Or worse, DPI requirements. Ack. Some may work with a PC but not a mac. This iPad particularly challenges one server I occasionally access. I have been doing this since the 80's and I've seen almost everything. One issue is the older systems were often written around what was around and common at the time by people lacking vision and intellenence. And some government systems no longer have anyone available who can understand or fix their software.
I'm sure this can be figured out. If we lived next door it might be trivial. I certainly would be willing to consult or process some images for you with Photoshop.
If something is broken on their system, can you submit images on a thumb drive, cd, or print?
Re: Very long but perhaps not long enough
John, I can't thank you enough.
I have struggled with this for years. I used to go to the site, inspect and take a couple of pictures with a Polaroid camera, fill out the forms and leave them there for the contractor to take to the bank and they forwarded them on to VA. Dirt simple on my part. Drive to, click, click, scribble scribble and run away fast. Then they decided they needed to go digital. DIGITAL I tell you. Had to buy a camera. $300 and had to buy Adobe Acrobat $300. But the good news is I am saving two bucks on those Polaroids. Turns out VA did not have a fillable version of the form so I had to buy a scanner also. (I have forgotten the cost.) OH! Now the process is to drive to, take the pics, return to the office, upload the photos, fill out the forms, Scan them, link to the photos, scan and link the bill, and then upload to VA, the Bank, and the builder. SEE how much simpler this paperless world is?
I have an older version of Word and Acrobat that worked fine. I am assuming VA has not upgraded there system or requirements. Now when I put the pics into Word and try to convert them to Acrobat/PDF I get "venetian blinds". A bunch of little stripped segments of the pic across the page and it freezes. I have to exit Word and start over after "recovering" the most recent version.
Acrobat said "You have an old version (6 I think) and we have moved on to 9 or maybe 10 and we no longer support your old stuff.
I should buy a new computer and All in one printer, and I probably will, but I don't really want to. Just don't want to spend the money and start all over. I have the newer version of Word at a friend's office, and the way I see it is, its different, but not really better.
My problem is that I don't really understand much of what you sent. Kinda sorta, but not really. I don't really know what VA size limits are, or what they mean. What I know is that what I have used to work. That tells us (mostly you) something.
I was riding around a few minutes ago (some of my best thinking time) and it dawned on me that I might be able to import the pics into Acrobat directly without going through WORD. Hmmm? I will give it a try when I get home.
I will look into Elements also. Thanks for the help.
Thanks to all of you.
There are some good ideas here. I knew there would be. I just wish I had the brains to sort it out.
Trying to screw up the courage to go buy all new stuff.
As for software, in decades of works I NEVER upgraded unless there was a compelling reason. I was typically years behind the latest, even with my operating system. And I NEVER installed any software unless I absolutely needed it. And my computers were always rock solid. Once I didn't turn off or reboot my primary computer for about a year and a half - there was no need.
Companies introduce new software for one reason - to make new money. There are usually new features to justify the cost but there are also new bugs, instabilities, and incompatibilities. Each release generally bloats the code and slows things down so you need faster computers and more and more memory to to the same work. I've seen so many instances of new programmers adding new features without understanding the existing code. They will NEVER understand since the brilliant team that wrote the original and the subsequent programmers who "enhanced" the code never documented it and are all retired now. There are huge systems doing our banking and such that no one understands and dares touch. Scary!
There is a perhaps counterintuitive way to work - to be compatible with an old system use the oldest computer and OS and software you can find. My version of Photoshop is at least 15 years old. I use a very old version of word. My laptop OS is at least 4 versions behind. I don't care if they no longer support the software if it still works. I don't buy the official answer to every problem - upgrade to the latest version. Ok, off my soapbox now.
As I mentioned, I'm sure we can figure this out. I'll be glad to help if you want.
First thing to do find and contact someone at the VA who can give you the upload requirements, if possible. If you can get a name/number I would gladly call them. I refuse to take mumbo-jumbo from these people.
chuck wintle
I have witnessed that very scenario where i work. We were using a custom program, they laid off the programmer and no one dared to touch it for 10 years. It was finally replaced by a much less capable piece of software.
A free option *LINK*
Lee Schierer in McKean, PA
You might want to upgrade to Open Office. It is a free program and will do every thing that MS word will do including exporting as a pdf file and compressing your photos when it does so.
Lee
Open Office
Dale Stansbery
P.S.
Publish It software has a 21 day free trial. It's so easy compared to trying to do what you want to accomplish in any word processor.
Jason Roehl in Lafayette, IN
One other possibility.
Someone turned me on to this program about 2 years ago: CutePDF Writer. Basically, it installs as a printer, so you choose it when you "print" the file you've created in whatever program, and it will create a PDF file in the location you choose.
For me, it solved an issue I was having with Quicken Home & Business that didn't allow me to save estimates and invoices to a file that I could e-mail.
Jason
Re: Thanks to all of you.
Walt
If you're going to buy something, I wonder if there's a camera that can be set to take low enough resolution small enough pictures to not require further manipulation. Digital camera marketing is all about megapixels because that's the only term most consumers know to look for. Even if they don't really understand why they want more megapixels - just that more megapixels is better which in your case it isn't. There should be a way to solve your dilemma without further lining some mega corporation's pockets.
