Construction or gorilla or ?
Gary Smyth
Awkward location. Not much leverage. Need to secure wood furring to house foundation (interior side) concrete block. I need to apply multiple layers to build up to final height in existing space.
Multiple house water lines are in the way so that I not only need to build out I need to build around and have the possibility of access at some unanticipated date.
Problem 1. Attaching furring to concrete block. Problem 2. Attaching wood to wood to achieve the correct height. Once at proper height surface treatment is to reattach some existing (no longer made) inexpensive 1/8" paneling. I have no desire to replace a total wall of the cheap stuff at this time, just get it back to look right.
I thought of using concrete nails in problem 1 but I have little room and do not want to risk breaking the block. No space for a drill. Lots of people do this I"m sure in many ways. By the way, the wall section (4'x6') once finished will have to support 60 lbs. permanently. Suggestions?
