Gorilla Goodness vs Gorilla Gloves *LINK*
Keith Newton
A builder friend who brings me a lot of work, ask me to help him with a customer change after the framers had moved on. Since I would have been making the roof frame, and trim anyway, to knock it out ahead of the roofers in two days. I got roped into just doing the whole job of extending the floor walls and roof of the entries.
He had all the material on site, but the only glue he had was Gorilla, which got me to grumbling. He said he calls the foam Gorilla Goodness. After about an hour of handling the parts, I held my hands up, which looked about the photo in their ads of the gorilla hand holding the bottle. I said, my favorite name for this is Gorilla Gloves, which took about 3 days to wear off.
Not a big fan of in-progress shots, but here is a link. The walls will be dryvit, slate on the mansard, Copper on the arch, and a wooden deck on top of the white roofing over the garage and entry.
https://www.flickr.com/photos/7391658@N03/sets/72157652910162662/
Re: Gorilla Goodness vs Gorilla Gloves *LINK*
good reason to avoid the stuff......
The chemistry used to polymerize the glue is known to be a "sensitizer" which is to say that some people will become allergic to it, in cases severely so. I don't put gloves on for much but in the case of this stuff it is a good idea. Well, it may be a better idea to avoid it altogether.
With sensitizers, you can never predict if or when you will start to have serious or even violent reactions to them.
Look up "diisocyanate".
Then read the Gorilla Glue MSDS (SDS):
http://www.gorillatough.com/sites/default/files/MsdsGorillaGlueEnglishJuly2013_0.pdf
You might want to even pursue an investigation of penetration of 4,4’-Diphenylmethane-diisocyanate through the materials used in different types of protective gloves.
I won't use the stuff, ever. There are other glues that work as well, or better, and are much safer for the user.
And I's surprised it wears off your hnds in only three days. It used to take about five days to wear off my hands.
Thanks William, I've never bothered to read MSDS
Keith Newton
there are plenty of other good reasons for me to avoid it.
There were about 10 contractor size tubes of construction adhesive that I would have rather been using, left by the framers. But there has been so much rain here lately that the cardboard tubes all folded up before anything came out the spouts.
As for my three days vs your five, only proves that I work about 40% harder than you do. Tee he.
Re: Thanks William, I've never bothered to read MS
There are relatively new OSHA regulations that make Safety Data Sheets more uniform, and hopefully easier to read and to find the information you need. They even changed the name from MSDS to SDS, I guess because they realized there are things other than materials that are also dangerous, like water moccasins :^)
I already knew you work a lot harder than I do. I couldn't figure out how to make a joke out of it, so I just set up the joke for you. Even when I was working full time, it still took about five days for ime to wear it off.
