dental crown cement
Jerry Gibbs
Just got a dental crown. What is the cement that is used and does it have any other uses. It has to hold non-porous surfaces in a warm, moist environment.
dental crown cement
Jerry Gibbs
Re: dental crown cement
John McGaw
There are several different cements used on crowns depending on the tooth's condition and the crown material. I know that my dentists have used at least three or four under different circumstances while fixing porcelain-over-noble-metal crowns. One type of cement requires a really disgusting pre-treatment chemical while another is UV fixed while another type is simply mixed up and applied. There is also a special type used for the temporary. There are online writeups about dental cements with various levels of technical complexity.
Jesper, Denmark
Google is your friend:
http://en.wikipedia.org/wiki/Dental_cement
Probably too expensive and in very small dosage containers to be of much use for other purposes.
Hank Knight
The last time I had some crown work done, the dentist used the glue that's fixed with UV light. He painted it on, clamped my crown in place, shined a little UV flashlight on it and POOF! the glue was cured and that's all there was to it. I thought it was really cool. The crown hasn't budged since.
TomD
Not that there is anything new about UV curing cements, but they have become ubiquitous in fly tying, though I am avoiding them due to my cheapness. They are instant, and there are all kinds of claims about their being environmentally friendly. And there are certain applications where the materials are difficult to stop from drooping, but instant curing solves that problem. Works for fly tying because most applications have the material fully exposed when the flashlight is turned on.
