Build One From Parts - videos
TomD
So this came up in the pressure washer posts. Two things.
1) The head of the great modern guitar company Taylor Guitars, Bob Taylor, has always made himself accessible to small builders. He did a column for a while on setting up shop and technical issues. At the time Taylor was not what they have become but was ramping up to factory scale, so the fancy home shop tools were no longer their thing. He had postings about how to heat stuff with industrial transformers. Anyway, His Key Piece OF Advice was learn how to weld. I would concur with that, with a welder and a drill press you can make a lot of stuff. I have never made a pressure washer (nor do I see much reason why one should since they are all over the place at cheap prices. Making your own stuff is not what it once was, given chinese goods, and the fact so much scrap is making it's way overseas). But basically it would be tacking some metal together and drilling a few holes so the motor and pump are coaxial.
Welding is a whole big deal in itself, but with lunchbox sized units under 200 it is well worth the effort to learn. There is a huge difference between welding test coupons for certification, and tacking junk together that if it breaks, you just tack it again. The first thing I made with a very unsuited welder was a gas forge, and it will never come apart. I know I weld better than a lot of stuff I see in harbor freight, and apparently people aren't dying all over the place, though I am not standing under any of their engine lifts.
2) Saw a great series of videos on prototyping. Somewhat limited by the scale of operations required, but I found it quite worthwhile. The guy who did them is a billionaire inventor and he owns a waterjet, and a 100 ton press. Some interesting safety stuff I hadn't tumbled across, and a process. As woodworkers we can fairly easily assemble stuff out of plywood and epoxy that he would waterjet fold and spot weld. Some of the interesting points he made were that the most efficient way to build anything is out of wire, if you can, and on up a hierarchy of methods. I found all the segments interesting, but the paint and glue ones would probably interest most.
https://www.youtube.com/watch?v=xMP_AfiNlX4
As a joke against myself, I noticed how he kept saying how easy it is to get this or that, and as usual I scowled that it is easy for an American to say that, try living in Canada... Well of course he lives in Canada... Still money makes the world borderless. So there.
