OT- Refrigerator Question
Tom
Our refrigerator does not seem to be getting cold. It is cool but not cold. Has anyone done any repair work on your own unit?
Advice??
Thanks!!
Tom
Advice??
Thanks!!
Re: OT- Refrigerator Question
Mine was dying so I called for service. They came, took the control panel out of the inside top, left it dangling, declared they could not help and left. Sent me a bill for a hundred bucks. I was stunned they just wrecked it and left. If they had reassembled it, I woudl have been more inclined to pay them.
I am not sure, but I think many of these systems are sealed and have no ports for them to add refrigerant. You probably can't add refrigerant yourself anyway, but maybe "they" can't either.
The first thing I woudl do is clean it. Where ever the coils are. Underneath or in back. Use a brush and a vacuum cleaner and thoroughly clean the coils. Might help with the heat transfer. My cat used to store his winter coat under mine. It was astounding how much stuff was under there and I thought we did pretty good house keeping.
Bill Turpin in WNC mountains
Modern refrigerators, unless defrosted with a butcher knife, just do not get low on Freon. If defrosted with a knife( hole in freezer coil) they are not economically repaired. The most common problems are DIRTY coils underneath or defrost problems. Most have a horizontal VEE shaped coil underneath. The BORGS sell an inexpensive long tapered "condenser cleaning brush" that makes the job much easier. Usually sold in appliance section. If you can't feel good airflow blowing from the freezer into the cooler side you may have a defrost problem. Some fans are turned off when the door is open. Cycle the door button for testing. There is a ~1500watt heater in the freezer that cycles several times a day to melt ice off the freezer coil. There is a defrost termination thermostat that turns the heater off when the ice is gone. There is a defrost timer that starts the ~fifteen minute defrost.
John McGaw
How is the freezer doing? If it is as cold as normal then you probably have a failure of the thermostatically-controlled port which lets the super-cold air leak from the freezer to the refrigerator compartment. If the freezer is not properly cold you might have a failure of the defrost components or the fan which blows air across the evaporator. You can usually figure out where the evaporator coils and fins are and pop off a panel inside the freezer to see what they look like. If they are covered with ice then it is likely that the defrost heater or controller is defective. The controller is easily replaced (but not cheap). The fan is usually pretty easy to replace and not too expensive. If the heater itself is bad then it may be time to buy a new refrigerator as it will be if the compressor is defective. Sometimes it is just a matter of unplugging the refrigerator for long enough for ice buildup to melt and the defrost controller to reset itself.
You might notice that I'm concentrating on two different main sorts of problem. That is because I've seen them crop up repeatedly on several different brands of refrigerator/freezers over the past ten years.
Ken Eaton
I've seen two evaporator fans go bad over the years. When that fan dies, air is not circulated over the evaporator coil in the freezer and the coil ices up. There is no cold air flow from the freezer to the rest of the refrigerator to cool it down but there is some coolness felt in the freezer. See if you can remove an inner panel in the freezer to see the evaporator coil and its fan. Hopefully you find an iced up evaporator coil because fan replacement is easy. (YMMV)
The second time I came across a problem like this, I could look into an air vent and see the fan blade was not turning. A pencil stuck through the vent got it moving for a little bit. Ultimately it was changed out.
Of course there's always YouTube University. Go to YouTube, type in your problem and go from there.
Good Luck,
Ken
defrost heater
GolfSteve in Calgary
Also happened to me a few years ago. Here was my easy $35 repair:
Re: defrost heater
Tom
I had a conversation with 1 appliance repair parts place. after describing the symptom they said " You have a leak in your system and you might as well buy a new refrig." Call a company to come out and after a bit he diagnosed it, bad switch that turns the defrost heater on. $26 part plus the service call. All is good.
Re: defrost heater
The defrost timer has an internal lever that is moved by a clock operated cam several times a day. The wire that sends power to the heater is spot welded to this arm. After ten years of wiggling, metal fatigue takes over, NO MORE DEFROST! A large flat screwdriver can be used to advance the cam to save your food until a repair can be done. Slowly turn until click is heard. Stop turning, wait for ten minutes, you might hear cooking noises inside freezer, turn until next click. Compressor and freezer fan should start. Wait an hour and repeat the process. Repeat once daily until repair is completed. Timer is apple size, usually black, at the front, on the very bottom. It has a 3/8" diameter hole that screwdriver will fit inside to turn
Re: defrost heater
John McGaw
Many refrigerators have no mechanical defrost heater control. Some are simple electronic equivalents which operate on a regular time cycle while others are 'smart' and attempt to predict when their services are needed and for how long. The electronic control units can be located anywhere but my experience is that they are as likely to be at the top of the refrigerator section near the temperature controls as anywhere else (ease of wiring at the factory?).
