Theft Proofing a locker question (OT?)
A family member runs several Learning Centers for kids and they have more than a dozen I-pads. They had a break in at one of them and the thieves stole about 18 I-Pads. It appears the theft was pretty targeted and they seem to have known what they were looking for. A friend and I have gotten them storage lockers designed for storing flammable liquids. They are made of sheet metal about the same thickness as lockers but have double wall construction. There is a key lock and a place for a pad lock.
We are on the hunt for gun safes that will be much stronger, but have not found any (cheap) yet.
Any suggestions on how to enhance the strength of these cabinets to make them a little more crow-bar proof?
Re: Theft Proofing a locker question (OT?)
John in NM
Hard to do. I would probably look for a heavy jobsite toolbox to use, but even those (or all cheap gun safes) are not much of a match for a fire ax.
Have they enabled the "Where is my iPad?" feature in iOS? It should help to some extent to maybe catch the thieves and get the iPads returned? Also, you should have recorded the serial numbers with Apple. I realize that this is "shutting the barn door after the horses have gotten out," but the iPads will need to be replaced, and the new ones will be tempting to the same scum.
Brian Roberts
Just a thought......it seems that it would be easier....and less expensive....to theft proof the building?
At the very least I would spend a hundred bucks....or so...and put alarms on the doors and windows that activated an EXTREMELY loud horn and a call to me and/or the law!
Security cams that record are also getting less expensive all the time.
William, you are right. I know nothing about I-pads but was thinking that such things as you suggest exist and should be brought into play on the new ones.
We discussed the fact that it has gotten to almost standard for the heat pump or outside AC unit to disappear on many of the houses we buy at foreclosure or when a rental falls empty. We decided to buy some stickers that say "This device protected by GPS Tracking" and stick them on the units. Figured it couldn't hurt. Sort of like people saying the most effective part of a home alarm system is the sign in the yard. Based on the idea that Loose lips sink ships, I told them to get similar stickers and put them on the I-pads and DO NOT tell the employees they are fakes.
Just found out the local public school was robbed the same night. Lots of hot Ipads out there.
TomD
Not sure how many I-pads we are talking here, but one option might be to drill two holes in a concrete floor and then hardware bond studs attached to a 1/4" wall tube into the floor. You weld a plate on the bottom of the tube, and you then epoxy the studs on the plate into holes on the floor, make it as low profile as possible so they can't use it as leverage. Then you slip fit a lid, and put a bar through that, with a lock on it. The bar should be in another tube so it can only be keyed. Same with the exit stud. That should be massive enough and if you are only talking 18 i-pads not too expensive. Mark with a gas symbol. You can seem similar devices holding gate hardware. But the strategy is twofold, make something really tough to get into out of parts that do not look like standard lockers or safes.
IPads, just take them home
Dick Coers
18 IPads would easily fit in a briefcase, just carry them home. As far as theft, there is always a way. I've seen film on TV, where they steal an ATM with chains and a truck. If they want it bad enough, it's gone!
Re: IPads, just take them home
The problem with that is they have four of these schools and as owners they rotate which one they are at at the end of each day. They are concerned that an employee may have blabbed that they had I-Pads and triggered the theft. (Probably not, because the public high school was robbed the same night, but you never know.) And, taking them home woudl just move the location of the theft and put who ever carried them at risk.
If they were mine and I had only one location, I woudl take them home.
Pete in Holland MI
A pretty decent locker to store valuables in (including guns), is a larger old electrical panel. We have retired machines here at work that have panels made from 10 & 12 gauge steel, that sometimes measure 6' high x 6' wide by 16" deep. Guys have made tool lockers, and even gun lockers out of them by remodeling the interior, and affixing a couple serious hasps & locks on the outside, and bolting them to the basement wall. Pretty tough, though not impossible, to get into and for minimal cost.
