Urn size
Urn size
Urn size
Janice Manuel
I know there is someone here that can answer this...
I need to make a box for a friend's ashes....would like to make a simple rectangular box...any suggestions on length/width/height?
Re: Urn size
Re: Urn size
Jerry Gibbs
I would check what size the friend wants. Will it be on a certain shelf or mantle? If the urn wanted is too small, many people spread the ashes in more than one place. I know of people who wear a neck locket with a few ashes. Not all of the ashes need to be in the urn for remembrance.
Re: Urn size
Re: Urn size
Janice Manuel
The size calculator says 130 cubic inches is the size....is there a formula for what size box will hold that? I have no idea how to do the math for it....
Gal's ashes are getting scattered, I expect the box will be more of a keepsake item...I'm going to put a scroll sawn picture on the lid...so would a 6" wide by 8" long by 4" high box be enough?
Re: Urn size
Re: Urn size
Pete in Holland MI
Length x Width x Height = volume of a container.
If the dimemsions shown are teh interior of your box, the volume will be 192 cubic inches.
Re: Urn size
Re: Urn size
Keith Newton
Janice, a general rule of thumbs is one cubic inch per pound that the deceased weighed.
Re: Urn size
Re: Urn size
Clifton C
Janice,
As Pete said 6x8x9=192 so yes...
For a visual, a measuring cup holds 14.4375 cubic inches. So call it 14.
130/14 equals 9.285, so call it 9.25. Measure 9.25 cups of rice and make
sure that fits into your box. If the inside dimensions are 4x5x7 that equals
140, so that would give a little extra.
I will admit to being a bit skeptical, so, I found a box that was 6x7x4.5 ID.
That comes out to 189 cubic inches, divided by 14 equals 13.5 cups....
Believe it or not, that little box held 13.5 cups of beans...Go figure, but
at least now I'm a believer...
cc
Re: Urn size
Re: Urn size
Geometrically, a box is a rectangular prism. (You can Google that.) To find its volume, you multiply its height by its width by its depth. If you start with the outside dimensions of your proposed box (4 inches x 6 inches x 8 inches = 196 cubic inches), you will not get the answer you need, because the thickness of the sides, ends, and top and bottom take up some of the inside space.
If you make the box from 3/4 inch thick wood, then you lose 2 x 3/4 or 1-1/2 inches from the height, from the width and from the length of the inside, leaving you with 2-1/2 inches times 4-1/2 inches times 6-1/2 inches. If you do the calculation, you'll find the inside volume would be 73-1/8 cubic inches, not nearly big enough. If you try again and instead use 1/2 inch thick wood, you only lose an inch from each inside dimension. Those choices would give you a space of 3 x 5 x 7 = 105 cubic inches. That's still not enough, but it's getting closer. You could try using even thinner wood, or you could increase any one of your dimensions by about 24%, or you could increase all three of your dimensions by about 8%. For example 3 x 5 x 9 = 135 cubic inches, which is big enough. So, one workable size would be a box 4" x 6" x 10" with 1/2" thick wood.
The important thing you should begin to realize by now is that there are a hugely unmanageable number of formulas you could use, starting with your desired volume, to design a box that is big enough but not way too big and way too expensive. Some of these boxes would be well proportioned, but some would be more appropriate for holding a snake or a pancake.
An effective way to solve problems of this type is to use a spreadsheet. They have been readily available for about 36 years.
http://en.m.wikipedia.org/wiki/VisiCalc
Since you are using a computer of some sort to communicate with us here on WoodCentral, you have access to one, and owe it to yourself to learn how to use it. Right now, I'm using Free Spreadsheet app on my iPad. I'm sure there is an equivalent for Android. I would recommend Microsoft Excel from Microsoft or Calc from openoffice.org if you are using Windows or MacOS.
Your alternatives might be to use calculus or linear algebra, disciplines which would be much more difficult to learn, :^) or even a pad of paper and a pencil.
