Frame for quilt questions
I have been asked to make a frame for a quilt.
The quilt (and the frame) will be permanently on display.
The size of the quilt would be 60" x 80". They want ALL of the quilt to show.
Therefore the interior dimensions of the frame would be on the order of 62" x 82".
Glass for the frame (1/4" tempered) would run about $250. Plexiglass would run about $100 more.
Plexiglass yellows and scratches, glass doesn't.
Glass weighs about 100 lbs or so. Plexiglass is much lighter.
Glass or Plexiglass?
I am leaning towards glass.
I was planning on making the frame out of red oak, about 1 1/2" thick. I was going to use 1/2" oak plywood for the back. I was going to cut rabbets for the plywood and a dado for the glass. I was going to use a single French cleat across the back to tie the sides (and top) together and a spacer piece of wood near the bottom to keep the frame away from the wall there.
How should I "bed" the glass in the frame?
Anything else to worry about?
Thanks.
