sharpening scissors
sharpening scissors
sharpening scissors
eliot feldman
I always thought that I could sharpen just about anything that had a knife-like blade. But , recently when I volunteered to sharpen a bunch of pretty badly worn scissors for a friend, I had a terrible time. It seemed no matter how sharp I got the edges, some of the scissors just wouldn't cut cloth (they all cut paper very well.) Cloth would often fold over and not cut. I did make sure that the center pin was tight. What do you think might have been going on?
Re: sharpening scissors
Bent blades?
Keith Newton
It would be helpful to know how you did what you did.
R. Payne
Scissor blades should have a slight curve to maintain pressure on the material being cut. Too much or too little will result in scissors that don't cut properly. Don't try to sharpen the wide face on the blade, only the top. The two blades should be sharpened at different angles, the specific angles will depend on intended use but 50 to 70 degrees for one and 60 to 80 for the other is common (note some people measure the other way with scissors and call it 20-40 and 10-30). The cutting edge shouldn't be polished, scissors need more "tooth" to grab the material being cut.
Knowing exactly what you did will aid greatly in determining why they don't work.
Re: Getting it right.
TomD
Paul is out of his league there.
The thing with scissors, is that the pivot experiences uneven wear, because areas in contact move at a different speed. So you can end up with the metal around the pivot differentially worn, and the result can be a rocking sensation around the pivot. Disassembly of the pivot varies in difficulty depending on whether it was designed for said disassembly. But once apart you can level the insides of the blades.
I have fettled my own scissors for about 42 years, but they were always bought new for fly tying and a simple sharpening routine on the Spyderco, followed by some tapping on the center pin, and some springing of the blades was all that was required. Since getting into restoring tailor's scissors from the 19th century, I have a whole new series of problems to deal with. So far I have dealt with them myself, but there is a guy who has written a ton of articles on doing this work, over on the Tailor and Cutter site. Hutch48I can't vouch for his ideas since I haven't read his articles, as I like to do stuff myself. But his occasional remarks in fora seem reasonable. C&T is an odd place where you can't post on most of the forum unless you are a working pro, and I am not really sure how this guy qualified, but it does make for an efficient experience, and you may have a lot to contribute, or not, but they don't want to hear from you.
http://www.cutterandtailor.com/forum/index.php?showtopic=3600&hl=shears#entry36171
I recently got into a side deal where I started making quillons for 2$ store scissors, as a joke, then realized they really worked better. I have a novel new design, that I was hoping to kickstart, but there are problems of there being too many types, and so far only custom solutions work well enough. It probably isn't going to go anywhere.
Eliot Feldman
O.K. What I did was to take out the center pin and flatten both blades and sharpen the way you would with a knife. I then fitted the center with a small bolt and nut. This way I could adjust the pressure at the center. I still had some problems with cloth folding over instead of cutting.
Keith Newton
If you flattened the sides which rub together, this is likely what caused the problem. Those faces are typically are not only hollow ground, so only their edges touch, keeping the corners in contact through the cut. They probably are canted inward, and may have a long bend down their length to make the ends tighter, rather than springing apart.
Also, it can be a good thing to have at least one of the top bevels not too fine a grind, and that should be perpendicular to the edge.
One pretty easy way I sharpen them sometimes, is to stand a portable belt sander up, with the handle clamped in a vice, with the belt away from where I stand. Since it isn't a good idea to clamp the handle hard, I let it lean into my chest, so I'm looking straight down the belt while it's running. With the other blade open all the way, this gives a pretty good idea of the grinding angle.
The handles are in my right hand, and my left is giving support to the back of the blade, I start as far back as I can, then lightly drag it across with the sander running of course.
I usually do a light first pass erring toward the heel of the bevel. Take a quick inspection, then adjust, and make a couple more light passes.
A 120 ~ 150 grit will leave a pretty fine serrated surface which will grip a slippery fabric that would try to squish out the front of one too fine.
TomD
Did you mention this earlier? Are you RH using RH scissors?
When you go to cut the cloth, pinch the blades together out by the point where they normally stop cutting. If this makes them cut beautifully then you have a set-up problem, if they still seem imperfect, they may either or also not be sharp enough.
