I am not sure the power washing is the way to go after talking about them. I have shingle siding on this new house I think they are 16"X24" or something from the early 50's and they are textured wood. what would be the best way to remove the flaking paint from this stuff? I thought abut power washing but now considering a brass wire wheel on an angle grinder. all that really needs hit is the south end and the bottom 2 rows.
I have that same siding, and I have used a power washer in the past. You'll have to play with the correct nozzle and distance from the siding, but it worked great for me.
there is some like it that is asbestos however this is wood several have cracked and need replaced or fixed. However that s a good point. that stuff is almost impossible to dispose of.
Is that a detached garage with the same siding? How about taking the siding off the far end and use the pieces to repair the house and then put something else on the back of the garage? Or, taking the gable ends off the house or the garage and replacing them with some other siding and suing that to fix the house.
You get the idea. Pick a patch you can do without to rob some pieces. Install a new window or door, etc.
Check at the Orange borg for "Grooved Cedar Sidewall Shingles"
We had/have them on our house when we moved in. I found these at the borg to use for patches etc.. (They make smooth and grooved, the smooth ones stand out like a sore thumb, so get the grooved the first time) DAMHIKT:)
Dick is right, they came as plywood backed panels, either four feet long or eight feet and about 16" wide. Pretty scarce around here. The shingles he posted might match, but you will have to figure out how to install them to match the thickness and details of the existing panels. Even if you do all that, its unlikely they will be a perfect match as far as the grooves or striations go and if they did yours have decades of paint on them and the new ones will stand out. It may still be better to do what I suggest and pull some original stuff from a less conspicuous spot, move it and replace it with the new stuff. Or, maybe not, you might be just expanding the "damage" for very little gain and maybe nobody will care, specially if the pieces you want to replace are fairly inconspicuous to start with.
A house I bought at foreclosure and converted to a rental had plywood siding with splash damage above the deck. Could not find matching siding. Cut off about three feet at the bottom and installed cedar as weather boards, stained it to match and nobody cares.
My middle son purchased an old country house several years ago with the tapered strip cedar strip siding (probably near 100 Yrs old.). The paint was badly flaking so he rented a large power washer. As I recall it took him a couple of days to really prep the house. He did a great job of it, considering it was his first time using a washer. The only issue was that when he started he did get too close and eroded some of the wood (he actually removed ALL the old paint in that area). Luckily the damage was minor and covered well with the new primer / paint. A few years later he covered the old wood siding with new high quality vinyl siding.
Besides the asbestos issue, you probably have lead-based paint from that era that would become airborne if you use the wire brush. Washing might well contaminate the soil, but it'll limit the spread to the area that is probably already contaminated by leaching.
