Laptop Desk
Tony - Memphis
My wife has been working from home and prefers standing to sitting, so I decided to build her a laptop desk (I'll use it too!). This is what I came up with. It can be used standing or sitting. Santa brought me a threader for Christmas, so I put it to use to make the adjustment mechanisms. The wood is cherry. No finish yet. I added a little personal touch to the base - my wife is an artist and me the woodworker/sawdust creator.
I made templates using a router on a jig I made. Routing those thick pieces is exciting! I used a double bearing bit so I could go either direction.
It will ride on casters.
These will be attached via tiny pins underneath and a dab of epoxy.
This was before I cleaned everything up and drilled the holes in the post too, but you can see the knobs. The top will tilt one direction about 20° max. I added a stop that is hidden. I wasn't happy with the holding power of the knob setup, so I added a pin that holds at 90° or ~7°. The 7° came from eyeballing what looked appropriate. I may add a "pencil" strip at the bottom that will attach from underneath if we decide we need it.
I built a little, just big enough, computer desk and figured that it was the solution to my problem but now there are so many things added on that I really should start over again. Too much stuff!
