My Powermatic PM1000 died mid-use a few minutes ago, and no longer runs. It's not very old -- I've had it a bit longer than a year -- and while I use it regularly, it's certainly not seen production-level use by any means. I have less than zero electrical knowledge regarding motors of any kind.
What I know:
I was running fine, and in mid-cut I thought I heard a hum sound. Nothing loud or particularly weird, just a motor humming sound that was different than usual. It sounded fine as I was making the cut, then a second or two at most of this hum sound (that may have been my imagination), and then it died.
The motor does not feel hot at all. It's warm, but just normal-warm from use.
The cut was not a heavy one, nor was I forcing the wood through. Just a nice, easy cut in softwood (cedar).
What I've tried:
I've checked the main breaker box, and no tripped breaker.
I plugged it into a different outlet on a different circuit. No change.
I pushed the reset button on the motor several times, and that didn't help.
So, any ideas as to what happened? I guess motors just die sometimes, but I have no idea.
I have no real clear Idea, but why not try resetting the breaker? Seems unlikely, but sometimes breakers tip without throwing the handle. Turn it off and back on and try again.
You mentioned your lack of electrical knowledge, so I am guessing you don't have a tester.
Could be the power switch or the centrifugal switch on the motor is cluttered up with saw dust, You might try blowing both the switch, and the motor out with compressed air. Are you running on 120v or 220V?
Below is a snapshot of the Maintenance page from the owners manual
The manual also mentions that the warranty on the motor is 1 year, so if cleaning things out doesn't get it going it'd certainly be worth a call to PowerMatic.
Just a thought you may already know this but some don't. You said the motor is warm if it was still warm when you hit the reset switch let it cool and try again. Earl
I have had that problem with my Jet, too. It may be the switch. Sometimes the magnetic contactor goes bad. Try testing and/or replacing the switch before you pull the motor.
These are great suggestions. Of course, I have no idea what a capacitor looks like... However, it gives me something else to tell a potential repair person.
I wish you were right! Sure would be nice if that was the problem, but, alas it's not. For one thing,when it died the blade spun down smoothly on its own. I also checked for that -- hoping dearly it was an easily fixed jam -- but no joy.
One thing I noticed but forgot to mention -- With the saw plugged in, the "power" light on the on/off switch is still lighted, however it seems like it might dimmer than usual.
This could be my imagination as I'm working from memory on how bright it usually is, and obviously reaching for solutions and causes, but it sure seems dimmer.
Is this a clue? (Or am I just clueless?)
Another question -- How, exactly, does one get a bad motor fixed? As I sheepishly admitted, I know absolutely nothing about electric motors. Nothing. Woodworking using things that have motors, yes. The motors themselves, no.
Do "electric motor repair" guys come out and fix it? Am I expected to remove the motor and take it to them? What if I take out the motor and they say it's fine? For that matter, do you even fix motors, or do you throw them away and get a new one? I truly have no idea what the process is.
Yes, just to remove any lingering doubt, I'm an idiot.
An electric motor repair shop will service the motor in their shop.
Disconnect the saw from the power source, take the cover off where the wires go into the motor, take pictures of the connections inside with each wire labeled using something like painter tape, disconnect the wiring and demount the motor after marking where the bolts go on the bracket and haul it to a motor shop.
NO, but it does "prove" you have power to the saw and that your circuits / circuit breakers are not at fault!
Don't know where your live, but am sure there is a motor repair shop near you. I'm sure they would come out for a fee, probably more than you want to pay! Normally, it is not a major job to disconnect and remove the motor (all with the saw UNPLUGGED). More than likely it is a "run Capacitor", if so they will replace the capacitor, test the motor for $25 to $50 and you then replace the motor on the saw. Replacement of a motor is pretty expensive compared to just repair, a motor as new as yours should not require major work.
Nope, I contracted as a second source of income for many years, worked at HVAC, Electrical and plumbing. I worked in many Doctors, Lawyers, Teachers, and business men homes and businesses that were quite intelligent and experts in their field ~ some had trouble replacing a light bulb! My primary occupation was Manufacturing / Quality Engineer, but I certainly couldn't compete with them in their field of expertise!
Have you tried to see if the blade is free to rotate with the saw unplugged? It would not be impossible for a bit of wood from a previous cut to fall into place and jam the blade leading to a power-on-motor-humming situation. I've had it happen with my old Robland.
Don't know if this will help...when I started having similar problems with my old Delta, I found that there was two caps on the motor - start and a run. If I gave the blade a whirl, then (with hands nowhere near the blade of course) hit the switch, it would run. Ran it like that for a while. I sent Delta an email asking about the problem (the saw was just out of warranty) and they sent a brand new motor! Wow! I still have the old motor, but the saw is in its next phase of life working for Habitat. Anyway, mine hummed like you describe and the problem was the start capacitor. Good luck. I hate to hear this as I have PM2000. No issues yet. There was an early issue with the motors on the 2000 where they would not start with a dado set installed. That was fixed before I purchased mine. Love the saw.
PS - your desk looked great! Still want to build a couple of those chairs in your article.
In an effort to do a workaround for a current project I decided to use my circ saw. Guess what happened when I plugged it in?
Nothing.
So I plugged in something else and... nothing.
Turns out that my drop-down power cord reel fed by a ceiling outlet was the culprit all along. I suppose plugging the darned thing in somewhere else should have been one of the first things I tried, but since the power light on the saw's on/off switch was coming on when it was plugged in -- albeit somewhat dimmer than I thought I remembered -- it never occurred to me the saw wasn't getting power.
Thanks for all your help, guys. I've actually copy/pasted it all into a Word doc which I've filed away for future reference.
Check what yours is rated for. They have copper contacts for the rotation feature that are the weak link is limiting the load capacity. I would go directly to a wall outlet for the future.
Hmmm... I'll need to think about that. Plugging into a wall with the table saw out in the middle of the room may be an issue. I trip over my own feet, so adding a cord on the floor might be a bad idea in my case.
The outlet I'm plugged into is the one in the ceiling of the shop that the garage-door opener is plugged into. That outlet is the only outlet on that circuit. In fact, that entire 20-amp circuit feeds only that one outlet and a single light in the attic over the garage. Obviously, when I'm using the saw neither the attic light nor the garage door opener is functioning, so the the saw pretty much has the circuit all to its own self. Does that make a difference?
I'm just talking about the reel, not the circuit. As I mentioned, there are copper contacts and "wipers" inside the reel. The male plug is connected to one side of the contacts, the cord and female plug are connected to the other side of the contacts. So these copper contacts have to carry the current. Pull the cord with the saw turned on, and you may get some arcing in those contacts. Do that enough, and the reel stops working.
A bunch of years ago I had my 1.5 hp table saw on the end of a 50' 16 ga extension cord. It was slow to start, underpowered, and popped the breaker a lot. I replaced it with a 12', multi-strand 12 ga wire and never had a problem again.
