some days it all comes together
Tom Sontag - St. Louis
And some days it doesn't.
Osage orange pegs into hard maple. Seven out of eight came out just fine. There is no woodworking task more satisfying than driving home a pegged joint, unless the mortise offset is too great....
Re: some days it all comes together
Two words
Neal in San Jose
Grain direction. If the peg had been turned 90 degrees, it would have been expanding across the grain in the base piece. As it is, it expands with the grain in the base piece, causing the base piece to split. Of course, I've never done that!
two sentences
Bruce, a MN Galoot
Sometimes you get the bear.
Sometimes the bear gets you. :D
What I've noticed about the latter is that is always when it's too late to salvage.
peg grain direction
I appreciate this thought Neal, but the split occurred as I drove the peg in. It was clearly an overdrawn joint issue.
But you raise an interesting detailed point: what is the correct orientation of peg grain to avoid any gaps over time? I matched the grain of the osage (a wood that is more stable than maple) with flat sawn grain of maple, so my peg should move LESS than the surrounding wood and possibly over time small gaps like parentheses might show up around the peg. If the peg did not expand at all (by inserting it rotated 90 degrees so the QS osage was matched with plain sawn maple) then I feel the small gaps would be MORE likely over time.
