Reversing Router Rotation
John Pierce
Can the router rotation direction be reversed on a PC 8529?
John Pierce
I have to ask why?
John in NM
Left hand cut router bits are not exactly easy to find!
(I've looked because my duplicator runs two of the 4 spindles left cut).
As to the question, I think you can do it by taking it apart and reversing either the field leads or armature leads - but I am certainly not sure of that, there's people around here who will know better than I do.
Re: I have to ask why?
John McGaw
I believe that would work but the results might not satisfy. IIRC the brushes/commutator in universal motors are 'biased' if favor of the normal rotation direction and would provide less torque in the opposite. But, as you say, why?
John Pierce
I have a rail cutter which allows the stile cut to be achieved by reversing the roller and cutter blade on the bit post. When I reverse them the cut rotation reverses also. Thus the existing rotation of the bit in my router will not work. I guess I will have to try and find stile bit which matched the rail pattern. So much for proceeding with my cabinet project.
Something is wrong here, no router reverses
Dick Coers
What brand of bit? I think you are doing something wrong, but I think I may need a picture to help. Maybe I can help if I know exactly what the bit it is.
Are you sure that is what it's designed to do?
John in NM
The reason I ask is that bits that are designed for left hand cut generally have left hand threads for stuff like the post nut. Could be that this bit is designed for quick changes without height adjustment or something like that.
I'm not really up on stile and rail sets, I thought most came with separate cutters for each - perhaps a mirror image cutter that you can drop on the same arbor post without having to re-index the height?
Re: Something is wrong here, no router reverses
John Pierce
After the responses to my question, it dawned on me that perhaps I should change the sequence of the cutters on the post rather than flip them over to achieve the profile I wanted. After I tried that I discovered that the cutting was in the correct direction and my problem was solved. So thanks for the insight.
Glad to hear it!
John in NM
Cool to get it worked out without having to buy parts
