Table saw value
Table saw value
Table saw value
Joe
I have an old Rockwell unisaw that I want to sell. Not sure of the value though. Model #34-466,w/10 "blade.
Can anyone help me?
Re: Table saw value
Re: Table saw value
Too many variables. A picture would help.
How many hp is the motor?
Which fence does it have?
What are the wings made of?
What sort of shape is the top in?
Etc., etc. As an example, a used contractor's saw can sell for $100-300. I've seen 1.5 hp Unisaws sell for about $200-300.
YMMV
Re: Table saw value
Here are some on Craigslist for reference *LINK*
Grant in Iowa
As JL said, not enough information. provide details about accessories and we can give better info.
I think a good working Unisaw with a 3HP motor, a 52" biesemeyer fence, and a blade or two generally goes for over $1000 around here. The older 1.5 HP units with the shorter fence or delta fence tend to be in the $500-800 range, maybe pushing $1k if they are in nice shape.
A late model unit with 52" biesemeyer fence 3 or 5HP motor goes for over $1K if it is in good shape. I have seen nice ones with outfeed tables and mobile bases go for $1500 used.
3 phase units tend to go for less money due to fewer hobbyists who can readily use them. Sometimes as little as $300 at auction.
I don't know how much of their value is a regional thing, but I suspect that might figure in too. Supply and demand and all.
FWIW,
Grant in Iowa<---sees stuff at estate sales go high or low...depending on the mood of the bidders.
link to saws on craigslist Cedar Rapids
Re: Table saw value
Re: Table saw value
John in NM
I bought one of the old ones with the 1.5 hp repulsion induction motor for $500 maybe 13 years ago in Tucson. Market was better then, but those old ones don't command a high price due to the odds of having to replace the motor eventually (I did a couple years ago) and the old jetlock fence they came with.
So I'd say under $500 if it's one of those old ones, and over $500 if newer, all depending on condition and fence options - and location of course. Out where I live now, I couldn't get that much for mine, but I could in Albuquerque if I wanted to deliver it.
Re: Table saw value
Re: Table saw value
William Duffield
I didn't have any trouble selling a Rockwell Delta 34-450 Unisaw locally six years ago for $300, even though it had a three phase, two hp motor without a phase converter and it had the old, non-Besemeyer fence. It was built in the late '60s or early '70s in Pittsburg, PA.
Re: Table saw value
Re: Table saw value
TomD
All prices are way down, because there is so much stuff out there, and the internet makes it easy to find. But to my way of thinking that makes the motor might burn out issue a pretty small concern. Most of the behemoths would actually be better in amateur shops if they had smaller motors anyway. But motors go for next to nothing.
Re: Table saw value
Re: Table saw value
TomD
For instance about 15 years ago, I bought one of the last Conover lathes, and the motor package I sourced for it was about 800 bucks. Today a motor that would do just as well might come for 150. As it happens I use it mostly for smaller stuff, so I put a variable speed 1/2 hp, and now use the 1.5 hp on a grinder. It got two of the 1/2 hp motors from off the net for 25 each.
Re: Table saw value
Re: Table saw value
William Duffield
I think the biggest problem with replacing the threee phase motor with a single phase motor is the mounting bracket and bolt holes. While motors for Unisaws have a frame pattern that is unique to Unisaws, it still is a standard frame, designated 66. For example, the motor plate from the original motor on my saw.
If you Google "motor frame" you can easily find all the critical dimensions. Then, all you need is some steel plate, a drill, and a welding torch.
http://www.engineeringtoolbox.com/nema-electrical-motor-frame-dimensions-d_1504.html
Re: Table saw value
Re: Table saw value
TomD
Cool!
