Time to makeover the bathroom. Took out the tub-shower and want to replace it with a shower base. Which one to get? Nobody has a selection to look at and I hesitate to get the cheap ones they do show. Anybody put one in that they like? I don't want to go the cast-iron route for two reasons-cost and weight.
I oversaw a bathroom remod in a house my parents bought. I wanted to put in a shower base as they're older and figured it would be easier to get around in.
I didn't have a lot of luck with shower bases in-store and had to buy it online. Cost a lot to ship but it came via a freight company (vs. UPS or FedEx) and was undamaged upon delivery. It's about the same construction quality as a middle-of-the-road fiberglass tub from Sterling or American Standard. The one in the link has a patterned floor that provides good traction.
I bought a 32x60 base but did not have to retrofit it into a 60" space. In retrospect, I wish I would have gone with a 48" base.....seems like it would be plenty of room for a standup shower.
When we re-modeled our bath I wanted a custom size to maximize our available space for a shower stall and went with one from KBRS and also bought their corner seat and 2 wall niches. They tiled up nicely and have had no problems(5 years).
When I did a remodel I made a built in base using a kit from Rona.. There are video's on line I'm sure on HOW to make a custom base, pouring a bit of cement and getting it to grade towards the drain was the most detailed part, I did use a rubber sheet specific for this purpose as well. After that it was a tiling job.
I installed a Schuter Kirdi kit in my last bathroom and absolutely love it. They come in various sizes and can be customized to some extent to get the size you need. I had to reduce the size of my base to fit the existing space and I reduced the height of the curb since it will be used by my elderly mother and I wanted to minimize the tripping hazard. This method of doing enclosures is the one way I know of to ensure that your shower will stay leak-free for a lifetime.
Thanks for your replies. I hadn't been looking at the tiled shower bases because I wanted to avoid the grout line cleaning. I also don't know if they can have the drain located at one side of the shower. All the ones I've seen have the drain in the center. That would require too much joist cutting.
The Schluter bases come in a number of sizes and with various offsets for the drain. That doesn't guarantee that there will always be a perfect match but it improves the odds. My old shower had an offset drain and an odd size and there was no problem getting a base to fit by cutting down one that was slightly oversize.
Tile should be very little problem using porcelain and modern grout and sealer. I did the walls in the shower with 12X24 (fewer pieces to mess up) floor to ceiling and 2X2 on the floor. I included a little niche for shampoo and suchlike stuff and put in a decorative band of 2X2 around the walls. Looks pretty good if I do say so myself.
