Veneering Question
Howard
After gluing redwood veneer to a small table top with Unibond 800 I found a area about one by two inches where the glue did not hold. It bubbled up about 3/16 inches. In the past when I faced this problem I would make a slit in the veneer, pry it open, inject glue and press the bubble down. In this case the veneer was to stiff to pry it open after making a slit.
I came up with a Rube Goldberg solution. It took a number 11 scapel and poked about 150 tiny indentations in the veneer, painted the area with a 50 percent water dilution of Titebond three, and pressed the bubble flat for 24 hours. Sanded after removing the clamp and bubble is gone and no evidence of repair.
Finished with BLO. And shellac.
Am I fooling myself in thinking that the repair will hold and that the bubble will reappear?
Thanks
Howard
