any one sanded and refinished floors? how hard is this really can I get decent floors sanded in 1 day to save on rental fees? should I rent the big drum one day and the edge sander the next or is it imperative to have them both at the same time? ismoping down the finish 1/2 as easy as it looks?
How many square feet do you have to do? What kind of shape is it in? What kind of shape are you in?
I have sanded lots of floors. There are lots of variables. You will find the big drum sanders to be the fastest and most aggressive and the hardest to control.
OTOH, the other machines like the U-Sand and large random orbit machine are much easier to control and much slower. (U-sand and U-sand and U-sand)
What I do is rough sand with the drum and then medium and fine sand with one of the other machines.
Keep in mind that the drum sander is very powerful and tends to drag you around all day. You have to keep the drum sander from running into the wall. If you let it hit the wall it will dig in and create a "gutter" along the wall.
There must be You Tube videos on this.
I could do a 12 by 15 room in a day, but if the space is cut up or expansive, it would take longer
And, I mopped the finish on with a lambs wool bonnet and it worked well. I can't stress cleaning up enough and waiting for the dust to settle. I have a dog and a cat and there are a few hairs in my floor.
Also, if your floor is in pretty good shape you may be able to "screen" the floor finish and recoat it.
the floor is in pretty good shape it is just the finish is flaking in the centers of the rooms. I have a house to do 900 SQ FT or a little less as the kitchen and bath are not hard wood. how do you do the sanding screen? I will look it up on youtube and see what they say.
Given the number of poor floor sanding jobs I have seen it must be hard to do it right. If you accept this premise, then what is the chance that you will get it right the first time without practice?
I've done about 800 sf with a rental from Home Depot or Lowes......like the U-Sand (basically a big ROS). I was able to sand through all of the grits in a day....or at least 24 hours. I didn't have need for the edge sander so I can't comment. The U-Sand may be slower but I think it helps eliminate problems, it really won't let you sand aggressively enough to do damage, unless you're really not paying attention.
I've put down oil-based poly with lambswool and water-based with a foam roller. Both turned out pretty well and I didn't have a whole lot of practice before then. I only wish I would have spent more on quality poly......I went with whatever Lowe's had for about $30-$40/gal. Spending another $100-$200 on materials might have meant the floors could go a few more years between refinishings.
The screen looks like a drywall sanding screen except it is bigger. One version is to use a floor buffer with the screen on it. About 16 or 18 inches in diameter. If you can run a buffer it goes pretty fast. OTOH, if you can't run the buffer, it will beat you and the house to death.
Check carefully about the finish. Try a small area to be sure the new stuff is compatible. Might be a good time to put down a resist coat of shellac and then a coat of excellent finish. I used Varathane with the Aluminum Oxide in it. there are other finishes that elude me at the moment that are rated highly. (Mega Bona Maybe?)
The U-sand and the big ROS may do a good job on screening and do not require an edger. We pulled the shoe molding and replaced it.
Let me stress the clean up part again. Vacuum, vacuum again. Then tack cloth.
thanks for the info I think I will give it a shot I will check out that machine as I was thinking about renting it at the local HD its a flip house but I will look into the better finish the floors look good except the top coat is flaking a little. and I hear you Vacuum Vacuum VACUUM!
A guy has to practice some place I will start in one of the bedrooms and go from there it it is looking sloppy I will stop and go with carpet or hire it done.
