Oil whine (albeit a minor one)
A.J. Hamler
A.J. Hamler
Wrapping up a cherry desk project that's getting a rubbed BLO/wax finish, and it's vexing me enough I felt like whining.
Bad time of year for oil finishing, as my shop changes temperature day-to-night more significantly than other times of the year plus the general dampness of spring is making the oil dry so sloooooooow it's got me wanting to scream bad words. (Something I never, ever do, dammit.)
Most every part of the desk is drying just fine, although achingly slowly, 'cept but one: the top. Something about the cherry I used for it that it just doesn't want to dry and it's taking several days per application. I just applied a light coat of BLO yesterday morning, and I'm still wiping off tiny bleed spots this afternoon. Doesn't help that the shop is slowly warming up a few degrees throughout the day.
Best solution would be to take it into the house and let it cure inside with constant temperature and more-or-less consistent dampness, but that's not practical in general, and with two cats in particular.
OK, done whining. Just wanted to share a good whine.
A.J.
p.s. I'll post photo when it's done.
Re: Oil whine (albeit a minor one)
put the cats in the shop
I was thinking you should oil the cats and put them in the shop. (OK, that's a bad joke, I like cats, and no harm was intended.)
How about a heat lamp to "cook' the top a bit?
Been there, done that.
The porosity of cherry is such that every once in a while, oil just seeps into the pores. What is really annoying is when you get little cured bubbles of finish.
Solution - fill the pores. When I am turning cherry, I will "burnish" the piece (leg, bowl or whatever) w/ shavings and saw dust. I then use a white abrasive pad to "dust" off the piece.
When I sand the piece, I typically take it a step or two further (greater than 220 grit). I dust with a shop rag or shop towel and rub the dust in.
Yup, I'm no fan of BLO despite.....
Dick Coers
all the internet woodworker's love of it!
One might ask...
... why you decided on linseed oil for the work surface. Apart from drying woes, BLO doesn't offer much protection from anything. It looks and feels lovely, but for table tops that will get abraded and abused, I'd suggest topping it over with a film-forming finish like lacquer or varnish. Once it dries, that is. :\
I'll bet it's beautiful though. Please do post some pix.
A.J. Hamler
Ah, Grasshopper...
A.J. Hamler
You misunderstand. You've inferred that "top" meant "worksurface." In this case, it meant "lid," as in for the shallow storage compartment at the top. Here's what the desk looked like week before last.
The "top" I was talking about goes, uh, on top and is hinged at the back like a piano bench. This is an in-progress shot here without the top, brass hardware (escutcheon, flush-pulls on the drawers), some half-round trim above the drop-down door that continues around the sides, and it's obviously still unfinished except for the two panels, which I gave a quick, light coat of oil to just to see what the grain would do before locking them in place. Since the drawers were done and separate, I've already oiled them several times and rubbed them out, and they're dry and ready to go.
A black leather blotter goes into the writing surface in the inside panel opening of the drop-down door.
A.J.
Curve ball
This is a fine reminder that things aren't always how they seem. Who'da thunk the top of a desk wouldn't be a worksurface? Touché.
What a pretty piece, AJ. It'll be an heirloom when it's done.
Cheers,
Nice!
John in NM
I like it a lot AJ, nice work!
Out here where it is dry and the air is thin, I can get BLO to dry in a couple hours by putting it outside in the sun. Tons of UV, but I think what it does is warm up the wood, speeding the process. Dry air helps obviously.
What I would try is getting a heat lamp and clip light to shine on it. If that works, I bet it's the heat since the lamps are mostly IR rather than UV.
Might be able to find one of those at somewhere like Home Despot, but I get them at the feed store. Since it's chick season, any feed store will have them.
Re: Ah, Grasshopper...
Yo AJ,
That's a beaut!! Awesome baby!!
T.
