Re: Older Festool Mini and HEPA filters
Rick Christopherson
Ugh, I was hoping someone else would answer, because I was too lazy to walk down to the shop to confirm.
Yes, the new filters, and even the holders, are the same across all CT Mini's.
However, unless you need to replace the filter, I wouldn't bother changing it just to change it. The difference is just a slightly finer pore size. As long as you've been using a collection bag, your existing filter is not likely fouled. (That's a testament as to how effective the bag serves as a pre-filter.)
Yes, the new bags are better than the older ones, in that they will break up any caking better than the stiffer brown bags.
The new CT vacs are certified HEPA. I don't believe there is any design change, but they have been tested and certified to not have any bypass air that does not pass through the filter. An older vac would be HEPA with a new filter, but it would not be certified HEPA (legal distinction).
