REAL MILK PAINT
Electric Random Orbit Sander/ Polisher
David Frame
Hi Ya'll,
I am in real need of a small electric ROS/P. Three inch to be exact. My air compressor will not handle such tools. If anyone knows where I can find electric sander/ polishers of this size, I would be grateful for your input.
I was wondering if a right angle Milwaukee 0370-20 3/8" Close Quarter Angle Drill or something similar might do the trick. I know it's not a random orbit tool, but is it possible to remove the swirl marks with finer grit polishing materials?
Thank you for your time,
David Frame
Re: Electric Random Orbit Sander/ Polisher
Metabo 3-1/8 inch
DLCinSTL
Google, "Metabo". They have 3-1/8 inch electric models. Made in Germany.
Re: Electric Random Orbit Sander/ Polisher *LINK*
Dick Coers
I'm pretty sure we gave you the only options available on your last post on the 10th. Are there other options are you looking for? Do you not like the looks of the Festool or Metabo? If it's price, the Metabo is the cheapest with random orbit that I know of. You can ask other questions on the old post if you like, it still adds on to the bottom of the list and comes up as new input.
http://www.woodcentral.com/woodworking/forum/messages.pl/page/2/md/read/id/488476/sbj/in-search-or-a-very-small-random-orbit-sander/
DizD
At our club meeting last night we were touring a local shop and there were also reps from Wurth Wood Group there. They had a new electric sander to show - SurfPrep Surge 3 X 4 Electric Sander. This had previously been only available as an air sander. You might want to check it out.
http://surfprepsanding.com/surfprep-tools/
William Duffield
But, he says he is looking for a random orbital sander. I don't see how random orbit is compatible with a rectangular sanding pad, unless it is a multi-mode sander like the Festool RO90, with interchangeable heads. I also don't understand why they are using it in the video without wearing a dust mask, and without dust collection. It doesn't even have dust collection holes in the pads, if you wanted to connect it to a vac. It's also curious why they emphasize the minimal power usage when operator salary and benefits, abrasives cost, and even replacement cost of the sander itself are much greater expenses. Another disconnect: While they claim "lowest energy demands over any other electric sander" they state their power supply draws 6 amps, which is 720 watts at 120 volts. I have only compared it to the Festool, which draws 400 watts, and the Metabo, which only draws 2 amps or 240 watts. I would guess that other ROSs of similar size have similar power requirements. If you are trying to judge its maneuverability or noise output, note that their video shows the air powered version, used without any dust collection. Their website doesn't give any prices, or even country of manufacture. I could go on, but I don't want to be accused of "beating a dead horse."
Looks good, Diz
That 3" SurfPrep air sander would be just the thing if it dowsn't need too much air. At half the size of a Dynabrade or Aro, it just might be stingy enough to run on a small compressor. I'd like to try one of those.
Re: Looks good, Diz
I got in touch with the company. They only sell through distribution, and I'm not sure how their individual distribution centers work. There doesn't seem to be a mail-order retail option.
Too bad. This puppy only uses 3.3 CFM @ 90 psi. You could run that from a very small compressor.
Yep
DizD
All that. I made a comment to pass along info about a new product that would perhaps meet the small size criteria David was looking for. I knew the new electric model was not ROS. There is an old story in marketing about a fella who goes into a hardware store for a drill - he really doesn't want a drill, what he wants is a round hole. If what was being asked was a finishing system that would produce the effect wanted, then it wouldn't matter how it was done. This system apparently uses foam pads of various thicknesses and maybe that produces results similar to what ROS system does - I don't know. That was why my reply was "you might want to check it out for yourself."
Re: Looks good, Diz
William Duffield
Now, that would be tempting, but my bench-dog-approved Rolair JC10 compressor only delivers two and a third CFM, so I guess I'll stick with my Festool RO90.
Re: Looks good, Diz *LINK*
Stuart Johnson
Looks like Sears handles them.
Surf Sanding
Re: Looks good, Diz
DizD
There is a "Find a Surfprep Supplier" box on the website and it has a PA company listed. I had my hands on the new electric version for about two minutes - it is heavy for it's size (made for commercial use?) but maneuverable where you are working on other than flat, horizontal surfaces.
I know he ask about electric, but sometimes *LINK*
Keith Newton
When you get down needing something for the small details, a small pneumatic random orbital sander is only used for the detail work, not for doing the heavy lifting, so working intermittently is probably more normal.
I've got a number of other sanders, but bought this one when I was having trouble finding a new pad for one of the older ones.
I like the feel of the pistol format, and the close proximity of hand to disk, for dexterity. Be sure to get an air line swivel to eliminate the stiffness of the hose, if you really need good control for details.
I couldn't find the cfm listed for this one, but it does come with a 2" and 3" pad, as well as an assortment of disk.
Another thing you can do to increase the capacity of smaller compressors, is to get extra portable tank, then T off the airline, which will greatly increase the reserve supply of air, giving a longer duration of sanding bouts before the compressor kicks on.
http://www.amazon.com/Chicago-Pneumatic-CP7200S-Random-Orbital/dp/B0002SRNO6
Isn't this Harbor Freight brand?
DizD
You can get 20% off and a flashlight there ;)
I think that is their Electric tool brand,
Keith Newton
But their pneumatic tools are Central Pneumatic. They do make a small RO sander though, and I have had one for probably 10 years or more, but I don't use it very often. It isn't quite as nice as this one.
21CFM at 15,000 RPM
DLCinSTL
That's according to the specs. from Amazon. In actual use it will be less because it won't be running free at that RPM, but it seems like it will still be a lot of CFM.
Re: I know he ask about electric, but sometimes
William Duffield
I have one of these 105° pneumatic ROSs,
http://grexusa.com/grexusa/products.php5?id=AOS368
which I like a lot, but at 6 SCFM, it is not compatible with small compressors, unless you have a large auxiliary tank, as you suggest. Even with the large tank, you need to be careful to not exceed the duty cycle limits of the small compressor, so you cannot use it continuously.
It is a true random orbit, and 1", 2" and 3" H&L pads and extension rods are available for it. I use it with Sorby and Wood River New Wave sanding pads available at Woodcraft.
