Have a question? Ask Woody!
Anybody have a Ceramic cook top on your stove?
I am sure some of you have the glass or ceramic cook top.
I got on recently. I am finding it to be a PITA to keep clean, maybe because it is black and well lit. Everything shows. Its not easy to wipe clean. Lots of smears.
I was wondering if any one makes a splash guard or some sort of cover like one of those silicon baking sheets you could use to cover the rest of it while using one burner?
Anybody got good ideas on how to keep it sparkling? Or am I just lazy?
Re: Anybody have a Ceramic cook top on your stove?
I do ...
Mike Farinella
You are not lazy Barry. I believe the glass and ceramic tops are two different animals. But are both hard to keep clean. I wipe them down after each use with Windex. If you have "baked-on" stuff, I use a single edged razor blade to scrape it off then uses a stove top polishing compound to finish it up. Not aware of any product to coat the top. Good luch
Re: I do ...
Gerry in North Surrey
Barry, you have acquired one of the most hateful things known to man. The guy that invented and foisted ceramic and glass range tops should be forced to maintain one. As you may have gathered, I have one. I've tried everything on it to try to keep it clean and have settled on a combination of a green type general purpose spray cleaner in combination with Bar Keepers Friend Multipurpose Cooktop Cleaner using a double sided spongey thing to scrub the top. Works better than anything I've tried before. The other solution is not to use the stove top and eat more salads. Better for your health and may save your shoulders from all that scrubbing. Good Luck!
I thought Windex was a No No....
I will read the book again, but I thought it said not use Windex because it had ammonia. I will double check, Windex woudl be a blessing. I have a bottle of "cleaner" and the little yellow scrubbies, but the cleaner does not work as well and the Cerambrite paste stuff, but it a PITA to get out and use every time. Quite a ritual.
Trying to avoid the burned on crud.
AZ in Colorado Springs
I have white cooktop. I use whatever brand of cook top cleaner sold at Lowe's and a Dobie scrubby. It's a bit scratched up but otherwise OK. Must be that black is harder to deal with.
Rick Christopherson
I have always heard people saying it's hard to clean the cooktop, but I've never understood why that is so common. I don't know about ceramic, but the glass top is incredibly easy to clean, and I wouldn't trade it for a conventional cooktop for anything.
It's glass afterall, and one of the hardest substances in your home. So the concern about scratching or damaging it is nearly zero. Mine is over 20 years old now, and the top still looks brand new, especially considering the amount of abuse I give it as a bachelor these last few years.
It's way easier to clean than a conventional stovetop. If it's too dirty to just wipe it down (usually the case in my kitchen), I automatically hit it with cleanser and a scrubbing sponge (scotchbright pad). If I've burned things around the elements, I keep a razor in the kitchen and scrape the rings at the same time.
I haven't used it in a while, but the cooktop cleaner is just an abrasive mix. It's actually more abrasive than cleanser. I have a full bottle of it, but the only time I bother using it is if I have film on the surface and want the top super shiny for company. It's almost like waxing the car.
Cleaning a conventional cooktop is much harder and more time consuming because it can get scratched, plus you have to take them apart to get under the burners/elements.
Rick Christopherson
I was surprised to read that your cooktop is scratched. Mine doesn't have any scratches. Are the scratches from cleaning it, or from the pans?
Lee Buck
I wipe my glass top with a damp cloth while the cook top is still warm from use. It is clean after I use it. My wife will not wipe it when it is warm and it is certainly more difficult to clean after she uses it.
OK, clarification: I have glass and not ceramic. Oops.
The scratches are ... well, more like speckles than linear scratches. It's from the bottom of the pots and pans, none of which seems to be exactly flat, but rock a little bit on the cook top. So they make little scratches that become speckled bits that are dark, because I think they get little bits of debris in there which are impossible to get out.
John McGaw
I do that too. Actually I sometimes do it when it is far more than 'warm' or at least the flash of steam says it is pretty hot. I've never had any trouble keeping it clean even when I've done something stupid like letting sugar-laden homemade cranberry sauce boil over. As others have said, those tops are made of pretty stout stuff.
Stuart Johnson
If she read this statement you'll sleep on the couch plus do all the cooking.
Checked with Samsung, Windex is a No No.
Samsung warns about sugary spills......
Apparently Samsung products are seriously damaged by burning sugary spills onto the cooktop. They have a whole section about cleaning them up quickly before the top cools. It warns that it can ruin the top and require replacement. Pretty sure replacement woudl be seriously expensive.
Hank Knight
My experience mirrors Ricks. We've had a black glass cook top for about 10 years. It looks as good today as it did the day we bought it. We clean it with soapy water (dish soap) after every use and polish it occasionally with glass stove top polish from the grocery store. If i use plenty of soap and water and a sponge, I can wipe the top down with a dish towel ant there are no streaks. If it's streaky, I hit it with more soap and water until all the oil/grease is removed and it wipes dry with no streaks. Occasional burned food gets scraped off with a single-edged razor blade, washed and polished. Caring for the stove top is just part of the dish washing routine at my house. It's easy and we love the stove.
John in NM
I use a mix of ammonia, alcohol, and water. Doesn't seem to hurt the glass, but I can understand people not wanting to go against the manufacturer recommendations.
Try just the alcohol for removing streaks. Doesn't have to be full strength, 40% isopropyl should be plenty.
Sorry Barry...
Mike Farinella
I have to respectfully disagree with you and Samsung. I have both a glass stovetop (Maytag) and ceramic (GE) range and I have been using Windex for over 12 years. I'm not dumb enough to spray the top when it's really hot - I wait until it's cool then I use the Windex. My users manuals say nothing about using Windex.
That's my story and I'm sticking to it!
Michael
Re: Sorry Barry...
I can't remember how I came to believe Windex was a No No. Maybe it was on the packing or some sort of quick start guide. I reviewed the book that came with the stove and it does not mention Windex or ammonia so I went on line to Samsung and one of their Chats. The person checked behind the scenes and came back and bluntly said no to Windex without any explanation.
I am lead to believe the "proper" cleaner leaves some sort of protective film behind on purpose. ????
I wonder what the difference is between glass and ceramic?
I will give alcohol a try.
Read up on the sugary mix warning. Its scary.
Now I am wondering about thermal shock
Does anybody guard against thermal shock? I am reluctant to set a hot pan from one burner onto a cold one to let it cool down. Or to set a cold pan onto a hot burner. Anybody had a problem?
Re: Now I am wondering about thermal shock
Hank Knight
Barry, we do that all the time withour glass cook top. No problem. Except for the cleaning, we treat this cook top just like any other stove top.
Re: Samsung warns about sugary spills......
Rick in Colgate, Wi
Our black ceramic stovetop was permanently damaged(pitted)when I boiled over a pot of maple syrup even tho I cleaned it up as quickly as possible. Other types of boil-overs have not caused any cleanup or scarring issues.
