parts for an old beaver lathe?
Edward in Vancouver
Really old. So old that both the headstock spindle AND the tailstock spindle are solid. No hollow tapers. If I'm ever gonna use this thing I really need some kind of a morse taper on both ends.
Anyone know of a source to find spindles?
Regards
Edward
Re: parts for an old beaver lathe?
Chuck in Mtl.
have you looked on the Busy Bee Tools site?
Ralph Lipeles
Sounds like a standard machine shop job. Drill out to correct size for reamer, then ream to size.
Ralph Lipeles
walta
I do not know what model you have but my guess is that this machine has a very small swing capacity.
This will limit you to small projects.
If you want to make a table leg the dead centers should work.
What projects did you have in mind?
It may be better to put this money toward a better machine.
Walta
Edward in Vancouver
Thanks for the replies.
Currently I'm working with a craptsman 12" tubular lathe, and I find this size meets 95% of my needs. However the banjo is very wimpy and the tail end frequently gets out of alignment. I use this a lot for felt wheel buffing, sanding, and drilling duties, as well the occasional tool handle or face plate turning.
The beaver has a 15" swing (gap-bed design) and is more robust with real cast iron ways. It lacks all the creature comforts of the crapstman however--no tapers, and no headstock indexing pin/pulley lock.
I took the tailstock spindle to a local gunsmith who informed me it is case hardned and he has no desire to touch it.
I'll be bringing the spindle around to a few machinists to get some ideas.
Haven't contacted busy bee yet, but will probably travel down there one of these days.
Edward
