ADVERTISE HERE - FREE TRIAL
Jet Lathe Speed Control
Jack Prescott
I have a Jet Model JML-1014I. This model does not have variable speed control except by shifting the belts on the pulleys. I want to know if it would be acceptable to vary the speed using a 110 volt / 15 amp router speed controller that I have without damaging the motor?? Thanks
Re: Jet Lathe Speed Control
Stuart Johnson
You would be better off asking your question on the turning board but I'm pretty sure it won't work.
router variable speed control won't work
Dick Coers
I've also read some poor reviews of the PSI replacement kit. Best to convert your lathe to a dedicated buffing machine and buy a new one if you want the variable speed.
John McGaw
They don't seem to say what sort of motor is on the lathe but it appears to be an straight-up single phase induction motor. That pretty much shoot down any sort of easy speed control. On a lathe that small I'd simply adjust my technique to turn with the six speeds that are available. Failing that, I suppose you could go searching for a VS DC motor that will fit (three-phase motors which are needed for variable-frequency typically being pretty sizable) and go for it after choking on the cost. Realistically it would be just as easy to find a different lathe and sell this one.
Jack Prescott
Thanks to all! Jet says do not do it = it will burn up the motor in a short while!
