Garage door Spring
Garage door Spring
Garage door Spring
Ernie Miller Topeka
how do you tell if you have a busted garage door spring? my door opens about 18" and then stops. really dont feel like messing with this one.
Re: Garage door Spring
Release the opener and try to lift it
Dick Coers
If the spring is broke, you will have trouble lifting it. If the spring is okay, you can lift it with light effort. Then you may have a wheel bearing or track issue.
Re: Release the opener and try to lift it
Ernie Miller Topeka
it is Heavy I was just wondering if maybe the tension had came lose? probably no such luck.
ben d.
I would say if the spring is broke you would know it. If the spring is broke you probably couldn't raise it any . Have you ever oiled the spring itself.?? , if not the coils will rust together so to speak and the spring does not slip within itself no help in spring tension to raise the door.
The obvious is to check that the cables are in place the chain drive from the opener has not hung up which can be verified by unlatching the drive with the rope, no brings loose to hang up. Is the opener still trying to raise the door.??
All checks oil the spring really good and it should work.
ben d.
Keith Newton
I don't think it would even start to raise if the spring tension was off, so like others have suggested, pull the disconnect lanyard, then raise it by hand.
Most likely where two of the track sections join, have become misaligned, causing a wheel to catch.
Ernie Miller Topeka
I called a guy to come check it out I trust him a family friend even with an incased spring I do not want to mess with it.
Tony - Memphis
Sorry for the trouble Ernie. My door is a double and has one spring along a shaft. When it goes, it goes. It sounds like a firecracker pop. We are on #3 I think in 17 years. I keep it lubed, but they still wear out. There are a couple of service companies in town here that offer quick and reasonably priced service (big business). We've been real happy with one of them. They get there quick and don't stay long. Good luck! I've adjusted a spring, but never replaced one and I've never seen them change ours. Not worth messing with for the price they charge. Our door would still move, but it is very heavy without the aid of the spring. I doubt I could get it open on my own.
Tony
Ralph Lipeles
Ernie,
You did not state what king of spring you have. There is a torsion bar spring that wraps around a tube and goes left to right across the top or side extension springs that are on each side. I have experience replacing or resetting both. Let us know which one you have.
Ralph Lipeles
Ernie Miller Topeka
it is a single spring across the top a guy will be here today to fix it said about 150 depending on the spring could be less. Gotta love them aswers as it never is.
Richard McComas
https://www.youtube.com/watch?feature=player_detailpage&v=QN325wddcq4
Ralph Lipeles
I'v reset them after replacing broken cables or having the set screws on the spring end fitting loosen. The trick is to do the work with the door open. That may require extra help since you don't have the spring to help. With the door fully open, push it back a little bit more and use a short piece of 2x6 to keep it in place. Now you will need a ladder and a wrench that fits the set screws. They are usually square headed. Hopefully you have a strong left hand. Set the ladder about at the end of the fitting. With your left hand pull the spring to the right a little and tighten the square head set screw with your right hand. The pulling to the right is important because when the door is in the down position there are more coils of the spring and room must be provided for them. Now remove the 2x6 and put the door in the down position. Everything should be good. If the door comes to a halt before it reaches the full down position, not enough room was left for the extra coils. If that happens, go back and repeat the previous directions.
ben d.
Just wondering what the final fix was on the garage door spring. Tell us so we all may know.
ben d.
Had the spring replaced $150
Ernie Miller Topeka
I am sorry I had a man and his 2 grand sons come out and replace it. didn't take them long and they did it cheaper than I could buy the parts.
Maintenance
Ivan
Home Depot sells a garage door lubricant that will help avoid a broken spring. They get rusty and break.
