Clamping Pressure Over the Glue Joint
don stephan
Recent discussion was interesting, but seemed to overlook one point. Picking some numbers out of the air, if the ideal pressure per square inch on a glue joint is 150, and a clamp can apply 3500 pounds of pressure, and that pressure were spread out evenly, that one clamp could apply 150 pounds per square inch over 23.3 square inches of joinery. Articles I've read before said clamping pressure spreads out at a 45 degree angle from the surface of the clamp pad.
Picture an edge joint between two pieces of pine 15" long, 3" wide, and 1" thick. The total surface area of the glue joint is 15 square inches, so a clamp providing 3500 pounds of total pressure is more than adequate, but only if the clamping pressure is applied uniformly to the entire 15 square inches. If the clamp is applied in the middle of the joint, and the pressure spreads out at a 45 degree angle, it is maximized over 6" of the joint. If the wood is somewhat flexible, like pine, little pressure might be applied to the joint at the two ends.
That is perhaps why many clamps are used on joints, or cauls to move the clamp pads away from the joint so the 45 degree spread reaches more of the joint.
The last article I read, in either FWW or PW, with pressure testing, said the limiting factor on how much clamping pressure was generated was hand strength of the woodworker, and that too much pressure could not be created by most woodworkers. Anyone have a cite for the article?
