Need a new dovetail jig w/ larger capacity
Would like at least 16" or more of capacity.
Leigh Super 18 or Leigh D4R pro?
PC Omnijig?
Akeda 16 or Akeda 24?
Re: Need a new dovetail jig w/ larger capacity
BrianMonumentCO
What kind of dovetails are you needing a jig for?
I am wanting to do some blanket chests and similar pieces.
Keller if doing through dovetails
It will do any length.
Re: Keller if doing through dovetails
Robby Wright - San Marcos, CA
I agree with Bill. You can easily slide the jig over for any length of dovetails. You can also vary the spacing if you want by marking where you want things and sliding the jig to match.
Love the Keller
Dick Coers
Works great on the router table. True definition of set it and forget it. You set the template to the bits once, and as long as you don't drop it, you never need to even make a test cut after that. Stock thickness nor bit height affect the fit of the joint. Bit height will affect how deep the joint is, but it won't affect the fit of the joint. I've done a modified half blind as well. Do a through dovetail, then glue on an oversize piece of 1/8" stock on the front of the drawer. Then flush trim the add-on to the drawer front. Boom, half blind.
