Bar Clamp Testing
TomD
I mocked up the rig above to measure clamping force. There is a 3.6 x 1 inch maple board that spans 22 inches (I had to check the actual pivot points on the blocks the board is resting on with feeler gages. The contact points were on the right side of the left block, and about 1/3rd in on the right block. The contact points were 22 inches apart as mentioned).
The only in-obvious detail in the set up is that for the board to apply force to the center of the scale, while being available to the clamp on the edge of the bench, the scale had to straddle the beam and a collection of blocks on the frame under the beam.
I started out placing the clamp on the "center" of the beam, which turned out to be at the 12 inch mark when I later identified the actual pivots. So the ratio of force was 22/12. In other words the read out on the scale would be nearly half of the actual force. Since the scale tops out at around 300, if the clamp was stronger than twice that, I could move it to the left so that 3-1 or 5-1 ratios could be achieve. (in theory, the strength of the piece of wood is a limiting factor).
The first time I tightened the clamp I got a reading of 170 x (22/12). That was using a lot of my hand strength, but not leaning into the clamp with body weight. I could hear minor wood snapping sounds After I took the fixture apart, I found a few dents and such, and a dent in the metal surface of the scale. I felt that was about all I would do in a real world situation. I also felt that I had probably sprung the board more that I would have normally. I got a deflection of less than 1/16" over the 10 inch length of my ruler, but that would be a lot more than that over 22 inches, maybe 1/8, which would be 1/4 as far as a spring gap to close, over 22 inches. I need a better rig to measure that though, if one cared. A dial indicator would be better. I do not feel my measurements were necessarily all that close, because for one thing they didn't vary than much at different loads.
I also noticed a dent across the face of the board from clamp bowing, I would guess.
I had to go get the camera, and when I came back I really leaned into the clamp, actually pulled on the clamp with my body weight which is considerable. That test which was certainly more than I would normally use yielded a reading of 277, but the original reading was 7, so call it 270. So all told that is 495 pounds. I know I have, normally in a bit of desperation, probably got that high in the past, and maybe more. The idea here wasn't to set a world record for clamp setting, but to get at least some idea what the loads involved are like before clamping pressure gets so high it badly dents the stock, or the applier of torque starts to feel he is overdoing it.
On the other hand I have seen jigs where bolt heads were closed with pneumatic ratchet handles. A 2000 lbs level would be possible, I would guess (the limit again being the stuff that is happening to the wood). But on something like the 7 inch wide by 1.25 inch thick boards I mentioned earlier you are going to get a 12.6 reduction in PSI without much coverage at all in some places unless the clamps are at least every 10 inches. That would be a net clamping force of 3465 pounds, with about 38.5 PSI, though it is unlikely the force is even. (table of boards of 6 feet x 1.25 x 7 inches)
The main thing is that it is easy to do this kind of experiment, and satisfy oneself what kind of pressure one can get. There is nothing definitive about these tests as people and circumstances vary a lot, but a lot of questions can be easily answered experimentally and in little time with stuff from around the house. The initial inquiry comes from at least a 20X disparity. I think this rig was within .2X, though the results are a lot more variable due to subjective factors.
