What is the goal here?
John in NM
It sounds like you want storage media for a specific purpose, rather than the sort of blanket, "back up everything" approach that most systems use. Knowing the little bit that I know about the Windows world, I suspect Jerry has hit on the answer.
It should be easy enough to separate the rar files from the others that you copied on your own - if not, then there is little point to having the backup in the first place. Unfortunately, you will probably need another storage location to get that external drive organized in the way you want it - got to put the files you keep somewhere while you nuke the rest and the software that made them.
Honestly, I find that a lot of these automatic routines to be more like viruses than useful programs!
I betcha the storage media vendors sure like putting a "no hassle" program on there that self installs and loads up 700 GB of space with redundant disk images in no time at all! Time to buy another external drive and start filling it too!
It's all about pushing product, just like the rest of our compu-lives.
But then I use linux, as I've mentioned before. Keep data in a separate partition and backup just what cannot be replaced with a fresh install of the OS. And my use is personal rather than business. I can fit the important stuff on a CD and live without the rest if I had to. Businesses tend to have larger requirements.
