Anyone ever use paper-backed plywood? *LINK*
Tim Greif - West of Chicago
I got a sheet of red oak 3/4" plywood from Menards that is paper backed. They list it as a utility LDO (low density overlay) backing. I'm using it on a project where the backing will either be non-visible or be painted on the inside of a cabinet. I've never used this stuff before. I picked this because the panel was very stable and dead flat. The oak face is high quality but will be finished using a grey pickled stain, so any face grain would have probably been ok. As I said, I got this because it was nice and flat and I will need 40" unsupported width.
Any issues using this stuff I should be aware of?
The link below is for similar birch ply
Paper backed plywood
Re: Anyone ever use paper-backed plywood? *LINK*
John McGaw
I've never used LDO plywood but I have used a bit of MDO stuff which is very easy to work with, quite stable and, originally being made for exterior signs, weatherproof. I'd suspect that your stuff will be about the same with the exception of weatherproof.
R. Payne
I would call MDO weather resistant instead of weatherproof, it will stand up for a few years of exposure. Also it is pointless to glue the overlay (paper), the paper will peel away under stress negating the glue.
Keith Newton
I've used a little bit of plywood which had mdo under the veneer on both sides, I suppose to reduce the print-through of any defects in the second ply, which sometimes shows up in the finish as a shadow or hump / glare.
So far, no problem, but it does seem a bit more fragile on the corners.
As far as other possible problems. You probably already know that an old turner's trick where a half or quarter spindle is needed, the blank can be glued up with craft paper in the joint. This can be easily split open with a chisel, right down the middle of the paper with no loss to saw kerf. A heavy face veneer may be prone to lifting due to paper separation in high humidity.
Lots of it
When I was a product manager in a contract furniture factory, we went through truckloads of this stuff. We also laid up our own kraft backer on tons and tons of flakeboard. (Ugh.) It is used to balance the veneer on the opposite face at the lowest possible cost, as it is cheap to buy and doesn't require finishing. It is used where the back face of the board is not seen, or where it doesn't matter.
