French Cleat
French Cleat
French Cleat
AZ in Colorado Springs
I've taken on a project for some friends who moved recently. One small bedroom is being used as a den, and to save floor space in the room, they decided to remove the closet doors and push the desk against the back wall of the closet. They got the idea from other friends who have done this, and have bookshelves as well, wall-to-wall and floor-to-ceiling around the desk.
But there was a snag. The door was too narrow for the desk. So, I cut the walls back on either side to create a larger opening (the carpet had be re-worked as well). Now the desk fits in there nicely, but there's only about 15" of space to either side of the desk. So, no bookcases coming up from the floor, but (nearly) wall-to-wall shelves above the desk.
The inside of the closet is 91" wide, and I'm building the shelves in three units, and there will be 1" of space to each side when they're installed (so I need not worry about how plumb or square the walls are at the corners). I'm going to hang them using a French cleat along the top (just to clarify, two pieces of wood, one mounted to the wall, the other mounted to the back of the shelving units, ripped with opposing 45 degree angles) and a spacer at the bottom to keep the shelves plumb. I'm going to use 3/4" plywood. And, of course, the parts on the shelves will be cut into three pieces, one on the back of each unit.
There is a question coming. I'm not sure how flat that wall is. I have a 4' level, but that's no where near long enough to be able to see if the wall is really flat.
So, I'm thinking that for the pieces of the French cleat "system" that are mounted to the upper backside of the shelf units, to put them through a drum sander and take off 1/16" or 3/32" to eliminate (or minimize) binding due to un-even-ness along the length of the wall. (The spacers along the bottoms of the three shelf units would be a full 3/4" thick.)
Is this a valid approach? I don't want these crash down onto the desk, especially while someone is tapping on the key board.
Cheers, Andy
Re: French Cleat
Re: French Cleat
Joseph Mulherin, sr
Hi, Andy, your idea of hanging the shelves is correct, and here is my suggestion for determining the dips or bulges in the wall..... drive a long nail into the wall where the cleats will be at each end of the wall, place a string, fishing line, or wire wrapped around the nails about 1" to 2" . then measure along the line and see where the dips/bulges are, then determine which cleat need to be shaved or wedge installed to hold the cleats and shelves straight across evenly.
Re: French Cleat
Re: French Cleat
Steve Jenkins
I would use a continuos piece to attach to the wall and your 4' level should work fine as a straightedge to shim the wall cleat straight.
Re: French Cleat
Ditto
Don't make it any harder than it needs to be. Shim the wall cleat straight and forget selectively thicknessing anything.
My two cents,
Re: French Cleat
Re: French Cleat
TomD
All good suggestions. One further option is to flush the wall, though not worth it in this case.
One thing you might want to consider is a modification to the french cleat system. The 45 causes a lot of unnecessary stress, which pulls parts together, and can aggravate the fit issues. One way around that problem is to use square pieces and allow the interlock to be a biscuit. In the case where one is say mounting tool racks, the ability to hang stuff anywhere along the cleat is important, but this is a fixed instalation, you just need to drop it in place. If you thin a top cleat with 45s you end up with a lot of wedging action on the cleat on your shelf
Under normal circumstances the high point will be caused by the build up to hide the seams in the drywall. One option if one were building from scratch would be to do a lower cat job so the build on the seams was not as high, yet fire rating of the drywall was preserved. Or another option is to insert plywood in the area you need to hang from.
Since the joint compound build is probably already there, use your straight french cleat, or the edge of one of your shelves (ply edges are straight) to find the highs. Then you just have to insert shims at the other studs. You can hang your cleat from the seams, and take the second cleat, or other straight edge, and sro in the spacers until the cleat matches the straight edge, then drive you screws.
I don't really agree that continuous to the ground 15 inch wide shelves are useless. I would put them in just to reduce liability. One really can't stop someone from putting their collection of lead bullets on the shelf, one can only overbuild the shelves. If you can't build to the ground, then I would use the gap at both ends to support the shelves to the walls, and hide whatever spacer blocks and screws with a scribed cap. I would build the shelves as much like a truss as possible.
Be sure you are using serious screws. I used huge ones, and they looked nicely industrial (though they probably won't show in your case) They were thick like pencils, and made of ductile metal that wouldn't just break off. I have wood racks hanging from my french cleats. The thing to avoid is anything hardened like drywall screws or maybe even some deck screws, or screws with self tapping features built in, unless you can confirm their suitability.
Re: French Cleat
Re: French Cleat
TomD
That wood is hanging from a cleat that did curve in and out across normal dry wall bends. But I located the load points, right over the screws, and the rest doesn't have any contact.
Re: French Cleat
Clint Searl
Re: French Cleat
Clint Searl
Forget the cleats. Better to lag a 2x3 ledger into the studs all the way across and under the shelving, and pull the shelving against the wall with screws threw the back. Easier and better support. Paint it the color of the wall and it'll disappear.
Re: French Cleat
Kneale Brownson
I like single wall cleat idea
Kneale Brownson
But I'd make it out of solid hardwood instead of plywood and use hardwood on the backs of the individual units. You could end up with a lot of weight on that shelving.
Re: French Cleat
Re: French Cleat
Clint, I installed all my overhead shop cabinets with French Cleats, I used oak cleats cut at 45 deg, and anchored them with 1/4" counter bored lag screws into my 2X6 walls. I have some 36" cabinets loaded with air tools (and other items stored on top) that I am certain exceed 400 to 500 lb. I have had no issues with either pulling away from the wall or any other failure mode in about 10 years of use. Why do you feel the cleats are not a viable and safe method? Have you had any experience with failure of this method?
I would be leery of using plywood cleats for heavily loaded shelves or cabinets, and would (did) opt for a strong hardwood instead.
Re: French Cleat
Re: French Cleat
Thanks to each of you for your great inputs.
Joseph -- great tip about using string to spot the irregularities. I should've thought of that.
I was planning to run continuous boards for the pieces on the wall. In fact, I'm going to install the lower spacer first (it goes about chest height), level it, and locate the studs. The use some 1x1 x the right length spacers to hold the upper cleat in place and attach it to the studs. I'll use #12 screws from McFeelys -- I agree that chinsy screws are not appropriate in this application.
Building down to the floor along the sides is not an option here. There are stub walls along the sides of the closets that would make this area difficult to access, and on the floor on one side of the desk is the computer-- a fairly good sized "tower." I suggested they get a laptop and just set it on the desk, but that was not well received.
Neither would the ledger board be acceptable. Good idea, though. I'll tuck that one away for the future.
I'll rethink using plywood for the cleats, and lessen the wedging action by ripping at a 30 degree angle. The three units will be screwed to the cleat (upper) and spacer (lower) to make sure they stay put.
Cheers, Andy
Re: French Cleat
Clint Searl
Re: French Cleat
Clint Searl
Larry, I live with several cleat hung projects, including big headboards and cabinets, so I believe them. Not so much with the headboards, but I think that cabinets and shelf units should be constructed with recessed backs to hide the cleats, which is a detail I'd prefer to avoid. I've had a 4'x4'x12" book shelf on the wall over my desk that carries about 200# for over 20 years. I didn't make it with a recessed back. It rests on a 2x3 lagged into a couple studs, and held against the wall with several 3" screws into the studs. It was easy to mount and accommodates any unevenness in the wall. Also easy to manage precise vertical requirements. I know it won't fall or pull away.
Re: French Cleat
Re: French Cleat
Thanks for the reply Clint, I thought you may have had some issues with the cleat construction, glad you didn't. When I built my shop cabinets, I did recess the backs (cut dado's in the sides, top, and bottom). I used 3/4 oak faced borg plywood for construction. Had no issues yet!
