Flat Tooth 10" Table Saw Rip Blade
Jack Prescott
I'm looking for a recommendation for a flat top tooth 10" table saw rip blade to give a flat bottom kerf??
Jack Prescott
Re: Flat Tooth 10" Table Saw Rip Blade
I bought such a blade to make flat bottom kerfs so I could install splines to reinforce miters.
I went to Wood Craft and bought a Freud rip blade that showed tooth geometry alternating between a square tooth and one with the corners nipped off. I Assumed the square tooth woudl clean out the corners leaving me with a flat bottom groove. Wrong. Ended up with a three sided bottom. Very disappointed. Fortunately, I had discussed what I wanted the blade to do with the staff at Wood Craft. Took it back and got a blade that did what I wanted. Very nice of them to allow me to return a lightly used blade for a new one. Somewhat more expensive, but it performs beautifully. I decided on a blade with an 1/8 kerf rather than one with a 1/10" Kerf. Might have been just as good with the thinner blade.
The point to all this babble is to be sure you get the one with the flat bottom kerf and the thickness you want. I am not in my shop right now, but if you need it I can look at the blade later and get you the part number.
mdclor
I use the outside blade from my 6" dado stack. It seems to work fine for me.
Ray Newman
I run a Forrest 10" rip that cuts a flat bottom. Believe that it is still catalogued by Forrest.
Walt
I think you want what is called a flat tooth grind. I use a Freud LM72 'heavy duty rip' blade. I'm sure all the major blade manufacturers offer similar. I have a CMT dado stack. The teeth on the outer chippers have little 'bat ears' on the outsides. The purpose like an ATB (alternate top bevel) grind is to make a clean cut. It does but at the cost of a tiny notch on the outer edge of the kerf. The Freud flat tooth grind is just that, flat. It's still a very clean kerf, no fuzzies.
Triple Chip Blades
What they sold you, Barry, is called a "triple-chip" grind, configured exactly as you described. It is not a rip blade, but rather an all purpose blade designed to cut veneered and laminate surfaces without chipping. Flat bottoms are not the objective at all.
Re: Triple Chip Blades
Now that you remind me, you are correct. It was my mistake to think the square tooth would "clean out" the corners. I truly don't understand the point or the square teeth otherwise. It was nice of the guy at Woodcraft to fix my mistake for me.
Robert
CMT makes a very good FT rip blade.
Freud LM72
Tim Greif - West of Chicago
Great dedicated rip blade with perfectly flat bottom.
