bandsaw blade sharpening
rfcomm2k
I have several blades ranging in width from 3/4 to 1 1/4 for my bandsaw and am having trouble getting someone to sharpen them. I posed this question elsewhere and got a list of shops, but every one of them states they do not sharpen bandsaw blades.
I finally tracked someone down thru a wood supplier, but when he returned my blades they had been laying in the back of his pickup in a box and were rusty. He also stated that he could not sharpen them any more because it was not profitable for him. I offered to pay more but he insisted on not doing any further business.
I realize that the cost of new carbon steel blades such as I use are comparable to the cost of sharpening a blade so I should just purchase new. But I cannot see throwing away a bandsaw blade just because it is dull, especially the larger ones.
Any advice? I live between Lancaster and Philadelphia, PA.
Re: bandsaw blade sharpening
do you have a Dremel?
robbcarr
I sharpen them on the bandsaw by just grinding the 'top' portion of the tooth so I don't have to mess with pitch, angle, etc. But, I have never been able to get them as sharp as new blades and after one sharpening by me I toss them.
Steel blades don't last very long and I have for the most part gone to carbide tipped, stays sharp a lot longer, but I too don't know anyone locally that can sharpen them.
TomD
I use a file by hand and don`t waste a lot of time over it. Just like a handsaw, freehand. This can be done a few times, and it significantly improves cutting, but it isn't retaining the geometry over time. Nor does it really ruin it, it just doesn't get the full value. I do it on the saw, if one really spent time on it, one could probably keep at it a long time. I sharpen like a rip, I don't bother alternating.
Chainsaw sharpeners are very inexpensive, and quite successful. I haven't tried one on a bandsaw blade, but it seems that the principles are the same, and it might work. I just bought an HF one, and may give it a try.
Check with Woodmizer
Keith Newton
They probably have a dealer near you that can do it, unless the tooth geometry is a lot different from theirs. I send my sawmill blades to a shop in MO, and their price is reasonable.
Worth a try DIY....
John in NM
I would give it a shot with a cylindrical burr and dremel tool, much like sharpening a chain saw. I would try touching up the inside of the tooth, that should upset the tooth geometry the least (at a guess, never tried it myself).
A nickel bonded diamond burr would be the way to go - Alox wheels would probably change size too much as they wear doing a whole blade.
