Which glue to use?
Which glue to use?
Which glue to use?
Ralph Lipeles
I have a problem with 2 overhead mounted kitchen cabinets. This winter The weather was brutal. I ended up with 6" to 8" ice dams on my gutters and 2 ' of snow on the roof. The kitchen roof has a valley between the house and the kitchen. Kitchen heat caused some of the 2' of snow on the roof to melt. The ice dams prevented the melted snow from running off the roof. So some of it backed up, under the shingles and came down, through 2 cabinets, into the kitchen. This caused the cabinet bottoms, particle board, to expand about 3/32" to 1/8" at the edges by the oak face frames. I have since soaked the areas with water and clamped the expanded sections between 2x4's above and below. I left the clamping in place for 4 days and then removed it. The expanded sections are improved but are still up about 1/16" by the face frame. They are slightly spongy. I believe that if I saturated these sections with glue and covered them with waxed paper and clamped them again, I could get them back into place. I expect that I need a glue that will flow very well and will be absorbed well. What glue should I use?
Re: Which glue to use?
Cyanoacrylate
It has exceptionally low viscosity and ability to wet surfaces, just what you need to be able to wick into the voids. However, there could be a problem. It gives off a massive amount of heat as it polymerizes which will have to be dissipated.
William Duffield
Just replace the cabinet bottoms. You'll never get the particle board to reconform to its original shape, and it will always be structurally compromised.
Cut them out with a jigsaw with a blade for wood and metal, trim the nails flush with something like a Fein Multi-master (there are lots of cheap clones), cut a new plywood bottom to fit, and attach it to the cabinet sides and face frame with Kreg pocket screws.
Dick Coers
Soaked particle board usually means mold. Replace the bottoms.
without seeing, it is hard to advise. *LINK*
Keith Newton
If there is any moisture still in there, the CA will flash so fast, it will smoke before it starts in good. Caution: don't inhale the smoke or let it get in your eyes.
If the parts can be cut out and replaced like William and Dick suggest, that may be best, but for parts that can't be replaced, the penetrating epoxy is made for this application. I wouldn't be wetting it anymore though.
If there is a small area still swollen but exposed, I think I would try grinding it down slightly below flush, then soaking it with the CPES, then after that has cured, use Bondo to finish back up to level.
http://www.jamestowndistributors.com/userportal/show_product.do?pid=1268
