Finish Preservation
Finish Preservation
Finish Preservation
Roy
I like to use tung oil finish and always have the problem of it gelling in the can. I have been using Bloxygen to keep it usable, but that means having a can of Bloxygen plus the finish constantly in use. i was wondering why somebody doesn't develop a container that has a spout at the bottom sort of like a picnic cooler. Put your finish in the container, give it one shot of Bloxygen and you're good to go. i would definitely buy one.
Roy
Re: Finish Preservation
Use a pipette, so you don't disturb the Bloxygen. You can put the unused finish back in the can the same way.
I am skeptical your suggestion will work
But I will yield to data if you know otherwise.
What ever finish comes out of the can is going to be replaced by air. If this air is not replaced by something inert then the curing chemistry will be initiated.
Finish taken from its container is going to be poured and maybe have a brush dipped in it. These events will saturate the finish with oxygen and the curing reaction is off to the races. My recommendation would be to never return finish to the can.
Clyde Collier
Take a look at Stoplossbags.
www.Stoplossbags.com
I use pure Tung oil, purchased from (as I recall) WoodCraft in Indianapolis 6 or 7 years ago. It came in a flexible plastic bottle. I have used quantities out of the bottle several times. When I remove some, I always "Squeeze" the bottle until all the air is completely out of the bottle, then screw the cap on tight. I do have to wipe some that escaped during the operation off the bottle and cap. So far I have had Zero problems with the material jelling, although the bottle looks like it has gone through a war!
Re: I am skeptical your suggestion will work
William Duffield
I yield to your skepticism. I had no idea the oxygen mixed with the finish that quickly. You know a lot more about chemistry than I do. Does it still make sense to remove the finish from the can with a pipette, but only as much as you need for the job, or is that also an "exercise in futility?"
"Does it still make sense to remove the finish from the can with a pipette, but only as much as you need for the job, or is that also an "exercise in futility?"
It may help.
Howard Acheson
One way to deal with the problem is to mix up your own oil/varnish mixture. Mixing equal parts of boiled linseed oil, mineral spirits, and oil based varnish will make a very good oil/varnish mixture. Make up only what you need so you don't waste it.
Just so you know, Watco and Minway Tung Oil are very close to an oil/varnish mixture.
