Straight Edges for Alignment
David Frame
Hi Ya'll
Does anyone know where I can get a reasonably priced 6' to 7' straight edge for aligning my DJ-20 jointer and instructions on how to align the infeed and outfeed tables to be parallel? It seems the infeed table is a about 10 thousandths lower closest to the cutterhead when I try to zero both sides. I contacted Delta, but have not heard from them as of yesterday.
Thanks for your time,
David Frame
Re: Straight Edges for Alignment
Re: Straight Edges for Alignment *LINK*
mdclor
Here is a 6 foot straight edge, but you might want to consider other options. :D
http://www.zoro.com/i/G0697155/?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&gclid=Cj0KEQjw3M6oBRDnnIywo5i287ABEiQAXRm7S-8Gdvjfctchemg8jWOpt_Eovr1vsmoSfscWGIU1yKMaAjf-8P8HAQ
TomD
Straight edges that long are really expensive, or not worth it. You might look into aluminum extrusions. A better way is the 3 point way. There was a very old article in FWW on this, and probably it is all over the web. You get three pieces of stable lumber and drive three screws into each, at the ends and the third in the middle. Eyeball or use some surface to get one of them (A) really good, but don't waste time on trying to get it anything like perfect. You then raise and lower the screws on the other two (B) and (C) until they both rst perfectly against the screws on the first (so for starters you need to have all the spacings nearly the same, and all the screws in very square holes). You then bing B and C together and they will either be perfect, or the middle screw will be relatively high or low (can't bring them together, or they don't meet in the middle). So adjust A to take this into account, and then go therough the process with B and C again, and until they are perfect. You now have three points that are in perfect alignment.
I forget how you use this to set your jointer, but it is easy to figure out. Yo can make AB & C the length of you table, and use them to see if the jointer table is flat, then you can overhand them with 2 points on one table and one on the other, and use shims and such to ensure they are coplanar, etc...
I'm sure you can find a tutorial. This is an essential machinist thing also.
By the way. You can do the whole process with planes, using three sticks and stop cutting with a jointer to get perfect edges, and that way you don't have hole sin some nice pieces of wood.
I have a rabone Chesterman scale from the 80s and it was 50 bucks then, and only about 36 inches long. It is tough to get stuff perfect, beyond a certain point defelctions are going to play a large part.
OK, here is a link, but this is taking the process much further to make actual perfect straight edges. You only need three points, but you can get the idea here.
https://home.comcast.net/~jaswensen/machines/straight_edge/straight_edge.html
The overall thing is that stuff you can make yourself is at least as good as a lot of the shinny things you might want to believe in enough. As I like to say, guitar scales are about 25 inches long, under 200 pounds of relentless string tension, and they stay nearly perfectly straight (if well made), indefinitely. They always have those fine wire/nylon builder's lines attached to them to tell you exactly what is going on. :)
TomD
I don't know your background, but one other thing is, do you know how to use a jointer. Because it may be good enough as it is, but unless one knowns, one may not be getting good result even if it is in tune... enough.
The illustrated diagrams on use, normally show running a piece that is already perfect over the tables with a given amount getting milled off. Even when doing that, it isn't quite that simple. But also, that is basically what a planer does (reduce dimensions), and certainly one way we use a jointer... But the real method allows you to get a bad edge flat every time, not one that is already jointed.
If the individual tables are each flat, you shouldn't need a 7' straightedge to line them up. I may be less fussy than others, but a two foot rule usually does it for me.
Jesse Cloud
I'm with Ellis on this one.
But, Lee Valley has some reasonably priced aluminum straightedges. The longest is 50", but that's good for what I do.
Lee Valley Aluminum Straightedges
Flooring trade supply store...
Grant in Iowa
I use a Crain 6' straightedge designed for use in the flooring installation industry. Google Crain flooring straightedge. 6', accurate within .003" over its length, and around $60 or so.
If there were a down side, it would be that it won't stand on edge on its own because it is only about 3/16" thick.
You might also find some of the high end aluminum levels available have similar accuracy ratings.
Regards,
Grant in Iowa
Here's the parallelogram jointer table alignment procedure: It works on the DJ20, DJ15, DJ30, Powermatic, etc. because their suspensions all work the same way.
http://media.ptg-online.com/media/dm/Articles/FAQs/JointerTableAdjustmentProcedureforJointerswithParrallelogramTables/20040123145450_J05.pdf
Door level
I have found that my levels are pretty good as straight edges.
Are they perfect - no. But they do work reasonably well.
A 6' door level will set you back $90-100.
procedure for alignment
Brian Roberts
Joseph Mulherin, sr
My take on how to be sure the tables are straight and true is to just use an extrusion of aluminum angle iron and a 3 foot level. You can see that the ends of the table are touching and the interior closest to the middle can be seen and adjusted by the screws to close the gaps, and then the table is true from end to end.
Re: procedure for alignment
David Frame
Hi Brian,
Thanks for the info on how to adjust my jointer. That procedure doesn't come in the standard manual. I called Delta, but sometimes we don't get any answers.
Thanks Again,
David
David Frame
Thanks William,
At this site, the price on straight edges, are reasonable. A 72" Starrett is over $800. That is completely insane. Anyway, Thanks again.
David
David Frame
Hi Tom,
I've been working wood for 43 years. Most people use a jointer just for getting a straight edge or flattening cupped, twisted or bowed woods.. Have you ever tried rabbeting with one? If the machine is very close to true parallel, it makes beautiful grooves on the edges of lumber.
Thanks,
David
Re: Flooring trade supply store...
David Frame
Hi Grant,
60 bucks is a really good price for a good straight edge. I'll take that advise and look around more.
Thanks,
David
Re: Straight Edges for Alignment and instructions
David Frame
Hi Ya'll,
I want to thank you all for your help. The last few times I've asked for help, you all have been there for me. It means the world to have friends I've never met help me. That is really why we're here, to help one other make it through life. I'm getting philosophical now. Time to go.
Again, I'm grateful for the help,
David Frame
