Need new Saber saw that uses "universal blades"
I have a pretty large supply of high quality saber saw blades, Starrett and other brands, to replace these with the same type and quality would cost well over $300.
SO, I just wore out my last Saber saw (actually had two, both are now worthless.
I am in the market for a decent quality saw that will use this style blade, willing to spend up to a couple hundred. So far while searching the web, I have found that most of the available current models require the new "T / bayonet style" or proprietary blades. I have not nor will I ever purchase any equipment that requires a none standard replaceable wear item (except for computer printers ~ and I hate that).
The only saw I have seen advertized is a DeWalt at Lowes:
http://www.lowes.com/pd_47180-70-DW317K_4294607771__?productId=1088259&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar|1&facetInfo=
Just hoping someone here has information as to whether this is a decent saw or knows of a better saw that uses the universal blade.
I don't use a saber saw a lot, have MM-16 band saw, old Jig saw, good reciprocating saw, routers etc., but there are occasions when the saber saw is invaluable.
Thanks for any leads you can give me.
Re: Need new Saber saw that uses "universal blades"
David Frame
Hi there,
If you are in need of a new jigsaw that handles all types of blades, including T style, except P.C. bayonet blades, it is a handle or barrel grip saw from Hitachi. It is a really good saw. My wife bought me a beautiful gold bracelet because I wouldn't wear a ring, for my wedding present. I asked her to get me a really good jigsaw instead. The Hitachi is what she bought for me. It is a really good tool. You may want to check to see if it still handles the blades mentioned above because she bought it for me in 1989. I still have and it still works like new.
Hope this helps,
David Frame
P.S.
I don't wear jewelry because I worked in the oilfield industry. Too many guys have missing fingers or are killed because there bling got caught on something in motion. I have all of my fingers and I'm not dead yet, although, I should be. 20 years ago, on the upcoming June 8th, I was in a really bad offshore accident where I fell 25' from one platform to a walkway and lived to tell the tale. The schedule 40 galvanized vertical pipe for the handrail saved my life. It kept me from rolling off the walkway, another 75' down to the water into the Gulf of Mexico. Each vertical handrail pipe has to be a maximum of six and a half feet apart. I'm 5'-8" tall. Can you imagine that kind of luck?
Re: Nope, new Hitachi only accepts "T" blades
Thanks for the info, but just checked their site. The only corded jig saw they offer is the CJ90VST Variable Speed Jig Saw with Blower, and it only accepts the "T" style blades.
Re: None Standard?
William Duffield
I'm not picking on your typing. I just want to make sure we are both on the same page. I assume you mean "non-standard."
When you say saber saw, do you mean a jigsaw or a Milwaukee Sawzall™ reciprocating saw (and it's clones)? Both types are referred to by the ambiguous term "saber saw" or "sabre saw." Your link to the DeWalt jigsaw does clarify your intent. Did you note that it is "NLA"?
I think the T-shank or bayonet mount blade is the standard. All the best saws use it, and there are certainly a lot more different types of blades made by most of the manufacturers in that type. Often, the makers of jigsaws even use the term "universal t-shank." The old standard U-mount blade is hardly universal any more, but I understand your reluctance to throw away perfectly good blades, and your annoyance with manufacturers' planned obsolescence.
Re: None Standard?
The terms apparently are ambiguous, although I have always understood a "Jigsaw" actually describes a stationary saw with a table and a blade that is captured on both ends, I assume the term came into use due to this type of saw being originally used to cut Jigsaw puzzles.
The name "Saber Saw" has always described a hand held saw that hold a blade by one end. As I recall in the 1950's one of the claims was that the saw could start its own hole/slot, therefore the name "Saber saw". Normally these held a 3 to 5 max length blade with stroke length's of 1" or less, and the primary use is to cut wood.
The third type of saw popularized by Milwaukee, was the "Sawzall". Apparently due to patent rights, the manufacture's of the clones of this saw referred to their product as Reciprocating saws. These saws are multipurpose tools normally used for both metal and wood with 4 to 12" blades attached by one end, stroke lengths are normally 1" or more.
As you have ascertained I am wanting to purchase a Saber saw!
Re: "Universal blade"
I actually found this definition on a saw blade site. The mounting area of the blade titled "Universal" was pictured as having a "U" shaped slot on the end and described as having one or two holes in the mounting area!
For many years this style of blade fit every standard Saber saw on the market. Sorry for the confusion.
You're right. That's the way it used to be. What I meant to point out is that the marketers for the manufacturers are changing the terminology, and if we don't understand the change and adapt to it, we may not get the products we want
Re: None Standard?
Your understanding of "jigsaw" is, in general, incorrect. If you google images of "scrollsaw", you will find pictures of Excaliburs, Hegners, DeWalts, and several lesser brands, some with tilting tables and some with fixed tables and tilting arms, and all with a thin blade stretched between the two oscillating arms. However, I know where your confusion comes from, and you're not really to blame. It's the same thing that confused me for many years: Sears used to offer a Craftsman jigsaw with a rotating head and blade that they called a scroll saw. I used to have one. (It had U-shank blades and two flat blade screws to change them, but that isn't important.) What is important is that it took two hands to operate it in scroll mode, when you could accomplish the same thing with one hand on any other jigsaw. I was very pleased when I replaced it with a Bosch, which can change blades without tools, and has several other advantages. I have since replaced the Bosch with a Festool Carvex, which is even a lot nicer than the Bosch.
While you've got Google's attention, ask it to show you pictures of "saber saw," and you will see that even Google is confused. I think it's enough to confuse Norm! If you ask it to show you "sawzall", Google gets it right, and shows Milwaukee reciprocating saws.
Re: The term Jigsaw
The term / name Jigsaw was used for many years prior to the advent of the current "Saber Saw" or "Scroll Saw". I was given a used Craftsman "Jigsaw" by my Uncle in about 1953 (long before the "Saber Saw, Scroll Saw or Reciprocating / Sawzall saws were invented.
Both of the Saber saws that just died on me are titled Scroll Saws (Craftsman). I currently own one of the old cast iron "Jigsaws" sold by Craftsman (Sears) in the 1950's, that I obtained at a yard sale.
I guess we will have to agree to disagree as my history and use of these tools is different from yours. The names have been misused and as far as the internet, many times the words used to describe or identify sites for the search engines are very broad so we can't use those as real identifiers for proper nomenclature.
A wise man once said of Standards:
Grant in Iowa
There's one good thing about standards, if you don't like one, there are plenty of others to choose from.
The DeWalt sabre saw is a good one. We have that model here at work (a museum) where it is used at least weekly. When I bought it, I did wonder about the tool less blade change feature causing a loose blade. The concern has proven to be unfounded, however, as it works great.
I have the older non-tool-less DeWalt at home that I have used for about 15 years. Love it too.
Re: Thanks!
Looks like I'll be buying one in the next week or so, next trip to Lafayette, IN Lowes. Appreciate the response, have a great day.
As a follow up, I stopped in Lowe's yesterday and purchased the DeWalt saw. Looks good, although I would have purchased the more expensive unit if it had the capability of using the old style "U" slot blades as it had more power and features.
Oh well, I may have to purchase one of the new style saws in the future that fits the "new standard" bayonet blades. Of course by then they probably will have a "new, new standard".
