Source for 5" Downcut Hacksaw Blades for Jigsaw
John Foster
Hello
I hope this is not a duplicate post, the first time I tried to post it never showed up. Does anyone know of a source for 5" downcut hacksaw blades for a jigsaw? I have Googled the major suppliers, the only downcuts they have are 4" blades for laminate counter tops. I want to cut inserts into steel skinned insulated residential doors. These doors are 1 3/8" thick, so a 4" blade is barely enough. While most blades will cut the 26 ga. shells on the doors, the finer the tooth the better. Shank style is not an issue, we will buy the saw to fit the blade.
Thanks
John
Re: Source for 5" Downcut Hacksaw Blades for Jigsaw
William Duffield
Why do you need a downcut blade? Are you concerned about the finished surface of the steel? Since you are cutting all the way through the door, the blade you imagine will leave the outside surface of the steel on the back side of the drawer rough. Why not use a blade that cuts on the pull stroke and make the cut from the back of the door? You'll still need to remove the burrs from one side or the other with a file.
John Foster
Dust Control
We are trying to make the air in our shop better. The dust collection available on most jigsaws is a joke. We cut our doors on the flat. If we had a downcut blade, a downdraft table would get rid of a large amount of the problem. Even with the regular blade a surprising amount of dust falls down. We have as good as they get Makita and Bosch saws. with the stock dust collection accessories we get a lot of the insulation dust, but miss a lot of the steel dust. Even with a downdraft table and downcut blades, I am sure we will still need some type of overhead dust hood.
John
William Duffield
Ah! That puts a different perspective on your problem. If there is such a thing as a metal cutting downcut blade, when using it, your "surprising amount of dust" will still come up off the saw. Note also that a down-cut blade will only work in "zero aggression mode." It wouldn't cut at all in any orbital mode. In non-orbital mode, if the stock you are cutting is thicker than the stroke of the saw, all of the chips won't clear and the saw will stop cutting.
I'm not sure I agree that the Makita and Bosch saws are "as good as they get." I'm not familiar with the Makita, but the Bosch does come pretty close to perfect, but I eventually replaced mine with a Festool. Have you checked out the Festool Carvex saws? They have surprisingly good dust collection when used with the Festool dust collectors. You don't have to buy one; just take a sample of your door material to your nearest Festool dealer and try out their demo model. If you do take one back to your shop, and are not satisfied with it, they come with a 30-day no-questions-asked full money-back guarantee.
Keith Newton
Another problem you may have with down-cut, is that any snagging will bend blades much worse than cutting on the pull stroke. This will be harder to control with coarser blades.
Another option you may want to check into is one of those air powered nibbler. You would drill a half inch hole near the corners to get started, then produce a metal ribbon as you go around. But I'm not sure if the insulation inside would prohibit the little underside portion from moving freely.
William Duffield
I figured John, and everybody else, already knew that, so I didn't mention it. But, I shouldn't have taken the chance. It's good that you brought it up, because it can be a real shock when it grabs and kicks back, and bends or breaks the blade.
The nibbler is a good idea, too. Well worth trying. There's a nibbler product out there, the Bad Dog Biter, that requires minimal clearance behind the sheet metal, and might have less problems with insulation getting in the way. Of course, you'd have to make two cuts, one from each face of the door.
The only downcut jigsaw blades I could find were 10 TPI wood cutting blades, specifically for clean cuts in laminate.
It seems to me.....
that another problem is going to be a tendency for the blade to grab the metal and push it down and out, bending or puckering the bottom side, making an exceptionally ragged cut. This would be true if the teeth are further apart than the thickness of the metal. With an up cut blade the shoe woudl press down on the top surface and help it resist the bite of the blade, but on the bottom it woudl be largely unsupported.
Would it be better to rig up better dust collection? maybe some sort of hood that has negative draft to collect the dust for the insulation, like in a clean room and an electromagnet to collect the metal chips?
And then there are always lasers.
George Koch
I would have the same concerns as other posters about down cut blades, especially of that length. The stroke of the saws are no more than 1" so why is a blade longer than 4" needed to cut 1 3/8"doors. I have cut many 1 1/2" laminate tops with 3 1/2" blades, and not had a problem.
