Bandsaw blade repair
Tom Pilsbury (Chicago)
Can I repair a 1/8" bandsaw blade with JB Weld? I'm thinking the answer is "No, it must be welded" but I thought I'd ask anyway. The testimonials for that stuff make it sound like it works miracles.
Re: Bandsaw blade repair
John in NM
No, but you can repair it with hard solder, also known as silver brazing. I've done it with a propane torch, but it's easier with something that gets hotter, like MAPP (never tried that) or air-acetylene. For an 1/8" blade I bet propane would work fine.
I have a little aluminum jig I used to use for this that keeps the blade ends nicely aligned. Used to clamp the blade ends to it with two binder clips.
I have no experience with soldering or welding. My son has a friend who is a welder by trade. I'll see if I can get him to tack it for me.
Joseph Mulherin, sr
Tom, go to YouTube and enter "repairing band saw blades" and up will come a video showing just how to set it up and weld or solder.
Joseph Mulherin, sr
and while you might get one saw blade refurbished, just go to "BandSawBladesDirect" and buy them using PayPal....very reasonable
Welding is tricky without a blade machine...
John in NM
Only time I got away with it using a MIG welder was with an inch and a half blade :D
Now if the guy does TIG or something similar, he'll be able to do it, those do much finer work than a MIG.
You could ask at a sharpening shop too, they often make up blades and will sometime reweld them. Sometimes they don't like to do so, thinking that you will keep coming back expecting free welds every time it breaks. A friend of mine got a nice blade welder from a sharpening shop because they were tired of rewelding a lot of blades. Struck me that maybe they weren't annealing the weld enough, hence all the breaks at the weld :D
My blade welder came off a big DoAll bandsaw. Machine shop bandsaws usually have a blade welder built in for doing inside circles and stuff, or so I've been told - cut the blade, thread it through the hole, reweld. If there are any friendly machinists around you could ask them about welding your blade too.
Re: Welding is tricky without a blade machine...
Joseph Mulherin, sr
John, go back to my first reply to Tom and also go to YouTube and and see for yourself the repairing of the blades soldering....not welding ......as in a machine shop or in the field on pipelines
band saw welding strategy
Everyone has a local purveyor of band saw blades that are custom welded from roll stock. Find and order from this place. When a blade breaks take it back for rewelding. If the break is at the weld they will reweld for free. They may reweld for free anyway. If you are near Morristown the place is Misenheimer.
I buy roll stock on Ebay, and hard solder
Dick Coers
all the time. I use a propane torch, all the way up to 3/4" wide stock. I use a cheap little fixture I got from Woodcraft. You need to sand a bevel on opposite sides of the blade stock to get a skive joint and use lots of flux. I cut a piece of hard (silver) solder on lay it on top of the flux. I heat from the bottom, and when the solder flows, the heat is removed. I then use a sanding drum in a Foredom to remove the excess solder. I used to use a blade welder at work, but I retired. I actually like the hard solder better as I think the stock is less brittle than welded. Proper tempering was tough to do on that old welder. It was a matter of bumping a switch to send electricity into the steel and watch the color. New welders are likely simpler to use. But, if you just need to repair a single 1/8" blade, this is too expensive of alternative. Just buy a new blade. Silver solder is EXPENSIVE!
I don't do youtube...
John in NM
Sorry, no time for watching a guy hem and haw and take 5 minutes to say what he could say in 1 minute if he just organized his speech and cut out all the ums and crap and did some basic video editing. Not all are like that, but 95% I've tried to watch just irritate me for that reason.
Soldering is the best bet for the average user, no argument there. OP didn't seem to want to solder though, so I'm offering other suggestions that have to do with having his son's welder friend tack it (his words). I've done that with big blades on a MIG, but it doesn't work well for most WW blades.
Re: I don't do youtube...
You are so right about all the blabbermouths on Youtube. Some of those guys take 20 minutes to say something that can be said in 20 seconds. However, there are some pretty good woodworking videos out there too. You just gotta hunt for them.
As far as any metalworking goes I have zero experience. When I think of welding I think of giant gas tanks and blowtorches and space helmets. That's why I was naively asking about JB Weld. Looking for an easy solution. So with my lack of experience and equipment there's really no point in me trying to repair the blade myself. More trouble than it's worth. I still have a good 1/4" blade that's in good shape so for the time being in doing ok. Thanks for all the info and advice.
Jesse Cloud
And you have to suffer through some crappy music and long credits before the tutorial even starts. >(
Re: I don't feel your pain...
TomD
If you are all so smart, why don't you put up some better stuff. Jeez, everyone is a critic. They are doing their best and there is tons of stuff on youtube you couldn't even get in a 39 dollar tape. Last night I was looking up Carp flies and I came across a video by a pro tyer, that gives away all kinds of trade secrets, and clearly just hands out his signature fly's competitive points. It was great. I have been tying since about '75, and at one point was very good relative to the field, and did pro tying, some TV props, and seminars. But I learned a lot from this video. I guess if one is really ignorant it wouldn't come through, one would just wonder why he filmed the whole thing with a go pro, and his carpet was so covered with scraps.
Some guys shouldn't be there, but there is plenty of stuff that it is just amazing, and not all of it is well produced, but the price of entry isn't travelling 200-2000 miles, sitting around for 2 days, and paying out 750. You just have to keep the monkey mind in check long enough to learn something. (don't be offended, if you got this far, clearly I wasn't talking about you).
I don't understand Youtube videos. I suppose some of them are money makers, but the vast majority just seem to be some guy exuberant about sharing what he knows. Even the stunningly bad ones were a lot of effort. I have learned a lot from them. Sometimes it was what not to do. I am not a mechanic by any stretch, but was able to rebuild my little roto tiller by watching a guy do it who had the exact model I did. Would have NEVER even tried without the video. A friend was rebuilding a bicycle and the quill was stuck. We watched a 15 minute video that actually took the guy days to produce. It was nearly a comedy routine, but in the end we got the information we needed. The guy claimed he went on vacation for a week or two during the process while parts soaked in PB Blast. What I don't under stand is why he went to all the trouble and what he got out of it.
OTOH, you have to be careful. Some of them are terrifying and promote things that are dangerous. Use your own judgement.
I want to thank all the people posting them. Keep up the good work. Long live You Tube.
Not a critic...
John in NM
Just a discerning viewer :D
If I felt youtube were actually important, I might be willing to put effort into improving it. As it is, I don't use it - aside from the occasional bit of music - and I don't find my life more empty for its absence. Therefore, I conclude that to me, youtube is unimportant and thus not worth the time or effort required to improve it. Others will feel differently, obviously, and they are as entitled to their own opinions as I am to mine. Some will find the slow pace convenient, and the music and credits fascinating and nuanced (I'd forgotten those!). No skin off my nose about that, all the better for them that I'm not hanging around and wasting youtube's bandwidth :D
Not me!
Tony - Memphis
I love YouTube. I can't begin to tell you all of the stuff that I have learned from posters. Lots of good shows too. Actually, I am constantly amazed, and very appreciative, of all of the quality posts that I watch. It takes a tremendous amount of effort to put that stuff together....and it is free! I subscribe to posters I like and have a pretty long list. Not all woodworking. You can learn LOTS of stuff, watch reviews, replay TV shows form all over the world (BBC has some great shows), museums post things there, etc. Like any media, there is some junk, but thats easy...just don't watch them! Lots of good car repair. home repair, etc. too. Great tool. Now that the app is on most DVD players, I can watch stuff while treadmilling.
Tony
Re: Not me!
Jesse Cloud
Good points above. I shouldn't be too critical of free help. I have learned a lot from them. Though one of the things I learned is not to stop at the first relevant video. Not complaining, but there are lots of ways to skin a cat and usually after I watch a few one comes up where the presenter clearly knows his stuff and shows it in a way that make sense to me.
I remember a few months ago, there was a great cartoon in the New Yorker. A husband and wife were walking in the park and she asked "Do you really know how to do that or just googled a video know how?"
