Finish and Humidity
Finish and Humidity
Finish and Humidity
Bobinnp
I posted earlier about helping a friend with a more durable finish on his table finished with Danish oil. I have spent most of my woodworking life in North Pole Alaska. Pretty dry climate. The table is in Spokane Wa. Raining here now and humid. Any thing I should be careful of with applying a wipe on poly after proper prep work is done? Thanks
Bob
Re: Finish and Humidity
Dick Coers
Nope. Slower drying is likely, but nothing bad like blushing in lacquer.
I would make sure that you have similar moisture resistance on the top and underside of the table top to prevent more moisture from transferring across the underside surface, which would induce seasonal tendency to warp. It doesn't need to be the same finish, just a similar degree of impermeability.
Ellis Walentine, Host
Dale Lenz
Dale Lenz
If you could add a little bit of heat to the area you are finishing the table would help alot, heat will drop the humidity in the enclosured area.
Tested some aged Watco Danish oil this morning, 0700, over BLO. I left heat on 65 degrees and ceiling fan on low. By 1300, Watco seems to be dry. RH was probably 45% or so.
Good luck
Dick Coers
You sure that's right Dale? No expert, but I thought warm air held more moisture? Warm the air and the humidity will go up won't it?
Dale Lenz
Warm air has the capacity...
Dale Lenz
to hold more moisture. There is an inverse relationship between RH and Temp. That is why our home's air is so dry during the winter. The RH maybe 65% outside with 40 degrees temp. Bring that same air indoors and heat it up to 70 degrees and the RH is going down.
Jason Roehl in Lafayette, IN
The difference...
...is that warm air CAN hold more moisture, but there has to be a moisture source. That's why it's called RELATIVE humidity. So air that's 50ºF and at 50% humidity has a certain amount of moisture in it that is 50% of what 50ºF air can hold. Add a heat source to that (that doesn't also add moisture--openly burning hydrocarbons adds moisture to the air) to warm it up to 70ºF, and there will still be the same amount of moisture in the air, but 70ºF air can hold more moisture than 50ºF air, so the percentage (RH) will be lower, maybe 20%-30%.
Jason
Thanks Jason
Dick Coers
well stated and easily understood, Thanks!
Re: Indeed thanks to all
Bobinnp
Thanks for the advice. Much appreciated.
Bob
