A little clock progress
Joe in a Cleveland suburb
Worked on my little clock a bit this weekend.
I decided to use one solid piece opposed to gluing up a couple pieces to get my 8" width. There were pluses and minuses going with the different options. The worst thing about using the one piece is that the piece I had to use has a stain on it running right up the center. I decided to use that as a "design feature" :) plus I didn't' feel like driving an hour to WoodCraft to get a piece... Once it is dyed and finished, it won't be as noticeable I don't think. At least, when I did a test piece, it didn't show as much. We'll see.
So I re-sawed the piece about down the middle.
Then I cleaned up both sides.
I decided to do a simple bevel to get it to fit into the grooves of the rails and stiles. Seems like it will work ok.
I still need to tweak it a bit, but so far it looks like it's going to work ok. It's a little tight still. This is the back side of the door. The raised field will be on the inside.
One problem I had/have is that I had a bit of tear-out on a stile right where it meets the rails. Not sure how I am going to hide that.
I suppose I could make a new stile, but I am sure the machining would never match as nicely as it does now and the wood would be different.
Maybe nobody will notice... :b
Thanks for looking.
Re: A little clock progress
David Yoho
Nice progress so far. Joe, I think your tear out problem is common with the wood you're using. I've worked quite a bit of curly maple and no matter how careful I try to be when dressing it there always seems to be at least one piece with this issue. Two ways to look at it are either feeling compelled to remedy it like if it is a piece of fine furniture or leaving it be on a utilitarian piece where function was more important than how finished it was. I don't think the Shakers would have worried about it.
You have several choices that only you can decide which is right. You could make a new piece but that didn't sound like something you wanted to do. You could fill it with whatever you like to use before finishing. You could fill it after it's finished with a variety of products used to fix scratches and such. You might also try a trick that might work and if not you've lost nothing. Even though this is not a dent or ding, steaming the area might help some by loosening and swelling the wood fibers. I think the best you could hope for is it works to the degree that the spots are less noticeable. That was my experience once and then I used a Timber Mate filler to finish it off. The result was a smooth finished surface that went unnoticed.
Fix it
On something as small as a clock the divots will be apparent. I would fill the torn places with the material of your choice. Over time the maple will age and the filler color won't match but the color difference will only show up under scrutiny were as the divots will show up across the room. You might see what you can scrap away (probably half) without unduly hollowing that area.
Alex Grigoriev
My dog approves of these photos.
mdclor
Joe, I think this will be easy to fill with TimberMate or FamoWood or AquaCoat (I haven't used this yet but it is highly recommended by Teri Masaschi and Michael Dresdner IIRC). However, if I understand correctly, this will be on the inside of the clock door so it will be invisible 99.99% of the time and then will only be seen by you or your heirs. On the other hand, if you haven't filled wood grain before, it would be a good place to learn about that process. FWIW
