Cyanoacrylate Glue
David Frame
Hi Friends,
I would like to know which super glue ya'll like the best. So far, I've used Satellite City, Mohawk, and Loctite brands. I prefer the heavier, thicker super glues like Satellite City Hot Stuff UFO Thick CA Glue best mainly because it gives me time to mix with sawdust to repair any goop that may have evolved in the building process of one my projects. I mainly use it on small work and it's all I use on humidors. The trouble I've found with this particular glue is the tips are constantly getting clogged and it has a short shelf life. I really like the Loctite Gel Brand because I believe there is a bladder in the bottle so that air cannot infiltrate it's container. It has a very long shelf life. I am aware that cyanoacrylate glue can be refrigerated until it's first use. After that, it can no longer be put back in the frig. I read that while researching these glues. I would be grateful for any suggestions you may have.
Thanks for ya'lls time,
David Frame
P.S.
You're probably wondering why in the world I would use super glue on humidors when it doesn't have movement like the wood. Well, it's the perfect glue for mismatched materials. As you know, some woods have oils in them whereas others have very little or none at all. I've have yet to have any of the humidors I make and sell fail. I will admit that it is expensive to use super glue, but it's worth the results. If you have any ideas on using different glues on humidors, please let me know.
Merci
