Unibond 800 Glue
Unibond 800 Glue
Unibond 800 Glue
Hal
Has anyone here had experience with this product in gluing up bent laminations (read bow front hall table) on a bending form? An article in the Oct. '14 issue of PopWood made it sound like a better choice than aliphatic resin (I mostly use Titebond III).
TIA for any info or opinions. Hal
Re: Unibond 800 Glue
Its short shelf life has kept me away from it. If the bend was not severe ordinary Titebond will work fine. Titebond III is a cross-linking resin so I would imagine it would perform well under stress in a tight bend lamination. If the bend is modest I would just saw it out of poplar and veneer it. It is a lot easier to do the joinery on something shaped like a plank and then make it arched by sawing the curves.
Jesse Cloud
I'm with Bill. I've made a few dozen bent lamination projects. Always used TBIII. Never had an issue.
Do try a practice run first to work out the process. Mark the lams with a triangle so they will stay in sequence.
If there's a way to make a mistake, I'll do it, so I always pencil in "NO GLUE" on the show faces of the first and last lam.
Make sure you have plenty of clamps and cauls within reach.
Watch the lams as they come together and tap them down if they begin to slide about - much, much easier while the glue is still pliable. :D
repeat point 3
Re: repeat point 3
Jerry Gibbs
I put blue/green tape on the no glue face in case I can't read that day.
Re: repeat point 3
Me too, I put the tape on the no glue faces and write on them. I still have to throw one away every no and then. I have so few active brain cells left one more woudl help a lot.
Tommy McDonald has a wood workign show on PBS. (If I had that other brain cell I could tell you the name.) Wood Works? On the show recently he made such a table (Demi Lune) recently. He used the brick method where he sawed out a pattern and faired the curve by sanding it to exactly what he wanted. Then he cut a bunch of short curved pieces and stacked them on the curve, screwing them in place from the bottom. Using a pattern bit with a bottom bearing, he trimmed them to the pattern. Then Installed a second course, offsetting the joints. Trimmed it to shape. Then a third course, etc until he built it up enough to get the width/height he needed. Then he veneered the front with really nice veneer.
One thing I did not like about the brick method was that he screwed the layers together and glued them. Left screws buried internally in the curve apron. I am pretty sure I would cut into one of them later. I guess you could remove them after the glue set but before you put on the subsequent layer.
I ave not done the brick thing, but I have done bent lamination with Tightbond and good success. Just throwing it out as another possibility.
Using unibond
McKay
I use unibond all of the time and find that it is an exceptional product. In fact, the glue line is ridged and will not creep as it may with other glues. I use the glue in a 15:1 ration that allows me to take the time for complicated bends. TB is too fast except for fairly simple bends. I have a small fridge in the shop that I store the resin and the hardener and it will last much longer than TB. I use a vacuum bag to do the bending and I usually use a home heating blanket covered with a Harbor Freight shipping blanket to cure the glue. I have found that clean up is easy unless I forget. In that case, I throw my 1/8" notched trowel away and go to Lowe's for another. Also, I have found that if glue gets on the veneer, it is easier to scrape and not leave a un-stainable mark.
The brick lay method has been used many times san the screws. I would not use screws but rather just clamp, move to the next "brick", glue etc. By the time you get from one side of the glue up to the other you can start another course of "bricks".
Re: Using unibond
jcousins
i have used unibond for many years - primarily for gluing down veneers. but several times have used it for gluing up thin slats in a bending form for legs and lamp struts - actually am finishing a music stand with curved legs.
there is minimal spring back - absolutely no creeping with a rigid glue line - and lots of open work time - and as someone mentioned easy cleanup with warm water.
i mix it by volume - 4:1
when i'm doing veneers it is in a vacuum bag with heat blankets wrapping everything - the heat causes the glue to set up in about 3 hours.
but the legs are cold bends - in open forms. for these i let them sit over night.
in more than 7 years i have only had 1 fail -never did figure out why - but stuff happens.
jerry
Alex Grigoriev
I wonder if Titebond I or II will be less prone to creep. They dry hard. Titebond III when dry is still somewhat flexible.
Joseph Mulherin, sr
I used TiteBond 2 when I was making my rocking chair rear seat slats and rocking runners with no problems. I agree TB3 can be dry and still have some creep.
don stephan
Place a small amount of any white or yellow glue on a piece of glass and let cure for a couple days. Gently peel it off with a razor blade or similar, and most people find the dried glue will flex somewhat without cracking. Do the same with a bit of Unibond or other plastic resin glue, and it will crack without any flexing.
Hal
Thanks all. Some great ideas. Differing opinions on Unibond 800 vs. Titebond III. Something to think about. Tape on top lam sounds about as near to idiot proof as you can get. But then there are those of us...................? Hal
