Have a question? Ask Woody!
Powermatic Red Grease - Leave it or clean it off?
AWH
Table adjusting gear rack on drillpress, locking mechanism on fence of the bandsaw and the trunions/gears on the tablesaw all have this red grease from the factory - manuals make no mention of it, and it's sticky! I'm concerned that once I start using these machines this grease will become impregnated with sawdust and cause binding. Right now the machines are new and I have the chance to clean it off relatively easily and replace it with something sawdust won't stick to... what would you do?
TIA
Tony
Re: Powermatic Red Grease - Leave it or clean it off?
Bob Entwisle in NJ
If it's a new machine, I'd call Powermatic and ask them.
Bob in NJ
A good question
It looks like the lithium grease I use on farm machinery. When I took a maintenance class from Delta many years ago the instructor lubed these sorts of parts with Johnsons paste wax, which I have used for many years myself.
DizD
When I got my PM2000 I cleaned all the gears and sprayed them with several coats of dri lube (PTFE? or something like that). I've had no dust buildup and am satisfied with the way the gears work.
awh
Well, this is my thinking too. I can replace it with something much better suited for contact with sawdust. I'm not sure why they would put a thick grease on these areas, aside from protecting the surfaces from rust during shipping/storage, but the cast iron tops only had a thin coating of oil on them and what was on the bandsaw appeared nearly dried up and took a good soaking with WD40 to remove the residual.
Tony
Kneale Brownson
Kneale Brownson
Maybe the grease is there to prevent rusting during shipment? Aren't all these parts made in Asia now?
