THE WOODRAT IS BACK!
Makita LS1214
Makita LS1214
Makita LS1214
John Foster
Do mitre saws go out of square? I seem to have one that is. There is no mention of squaring up in the manual, and I can't find any adjustment on the saw. Is it just my imagination, or am I missing something?
Thanks
John
Re: Makita LS1214
Re: Makita LS1214
McKay
I have the 1214F which is an older model. I had a newer one and did not like it so I got rid of it and kept the older model. I have had to replace the fence because if you jam a board it will often tweek the fence out of square. You can check this using a known flat surface like the table saw or jointer beds. The miter gauge is also able to be moved a small amount to line up the degree. If the detents do not line up correctly, I am not sure what you could do.
Re: Makita LS1214
Re: Makita LS1214
Allan Wessel
Here is a link to a web page from the manual which describes how to square it back up.
http://www.manualslib.com/manual/294309/Makita-Ls1214.html?page=29#manual
Re: Makita LS1214
Re: Makita LS1214
Personally, I have never seen a miter saw that cannot be adjusted for angle.
The link provided by the previous post does explain the steps for your saw.
However, I would like to explain how I insure the 90 degree can be checked very accurately without any tools.
Step 1) find two scrap boards about 4 to 6" wide 2 to 3 foot long, that are not tapered on the width.
Step 2) Saw one end off on the saw set at 90 Deg. and clearly mark that end on one side, and mark the edge that you have against the miter saw fence. Repeat for 2nd board.
Step 3) Set the 2 boards one end, face to face, on a flat surface (I use my Unisaw table or my cast iron planer extension as I have checked these surfaces with a LV straight edge and know they are flat within <.0005").
Position the edges of the board so the marked edges are perfectly aligned at the bottom. Check that edge all the way to the top of the boards. If the two edges are flush your saw is perfectly aligned.
If they are not flush readjust the saw and repeat the above until they are. If you are unsure you have a "flat" surface the boards are set on, reposition them on the surface and recheck, if the surface is not flat the amount of misalignment will change and will be obvious.
The average person can "feel" less than .001" misalignment. If you follow the above your saw will be set more accurately (.001" in 24") than a precision square.
Note: I believe I "discovered" the information above in a post on this site many years ago, so I can't take the credit. I have been using this method for years and it is by far the most accurate way I have found.
As I have stated before I have a certified calibrated square I use to set my working squares. I do use an accurate square to "rough set" the saw then use the above to verify I have it perfect.
