I am in the process of buying a set of Freud Forstner bits PB-100 but then I came upon a question what is the difference between forstner bits with serrated edges and without serrated edges. I can't seem to find an answer on the internet. I would like to find out before I buy a set. Does it really make a difference in cutting the wood. Right now I have a set made in China and they suck. Thanks for any help.
I was always taught that the saw-edged bits minimized the heating of the rim which is often a problem with 'regular' Forstner bits. In real-world situations I suspect that there is little difference between them. FWIW, I have Freud Forstner-pattern bits ranging from 1/4" to 1-3/4" and have never had any trouble with them -- only a few of them have needed touching up with a diamond paddle in over a decade of use.
I don't do that type of woodworking. My lathe usage is making spindles for cribs, table legs tapered,
and things like that. Using my lathe duplicator I can make multiples of almost anything of the original design......not drilling on hardwood end grains.
I haven't used the Freud bits, but I have used the Famag Bor-Max bits (Also German), and am very pleased with their performance. Colt bits are also high quality.
The technique for preserving your Forstner bits, either the cheap Chinese or good quality German, is to keep from overheating them. (This is very, very difficult to do if you are using them in a lathe.) Plunge quickly, and immediately retract them completely from the stock. Stop plunging immediately and retract if they clog and stop ejecting chips. Don't try to drill a deep hole all at once. When you've retracted them, let them cool off, while continuing to spin.
If you follow these procedures, there's no reason to spend a fortune on a complete set of German bits. When I've finally worn out one of my Chinese bits, I replace it with a Famag. I've drilled hundreds of holes in rock maple with one 3/4" Bor-Max bit, and recently also replaced my 5/8" Chinese bit.
